NAD DAC2 Wireless DAC with RF Transmitter 24bit 96kHz
With the NAD DAC2, digital music meets audiophile sound. This simple and highly efficient solution allows you to listen to the music stored on your computer directly on your HiFi system, seamlessly and without the need for a WiFi connection, thanks to its RF transmitter. The wireless point-to-point technology allows for a simple installation to enjoy your audio files up to 24bit 96kHz, without compression.
Reference : 16501
249,00 €tax incl.
207,50 € tax excl.
NAD DAC2
NAD DAC2 DAC Sans-Fil Émetteur RF 24bit 96kHz
The NAD DAC2 consists of both a DAC and a USB RF transmitter module, offering a range of up to 40m. The DAC2 is also the possibility to enjoy your favorite streaming services and web radios. To further enhance the experience, many mobile applications will allow you to control your PC or Mac remotely.
The signal received via the USB input of the RF transmitter is directly transmitted wirelessly to the DAC2's digital-to-analog conversion module, which uses high-quality components such as Burr-Brown AOPs, a Delta-Sigma 24/192 DAC and a selection of passive components, all within a proprietary NAD circuit.
1Transmitter channel selection
2Mini USB 2.0 input
3Analog output
4Digital output
5Coaxial output
55VDC Power supply
6Right channel RCA output
7Left channel RCA output
8DAC Channel selection
Product typeWireless DAC
Inputs1x Mini USB 2.0
Outputs1x Stereo RCA
1x Coaxial SPDIF
Supported sampling ratesPCM up to 24bit 96kHz
THD+N0.05%
SNR> -80dB
Analog output level2V
SPDIF Coaxial output level500mV ±50mV
Frequency response20Hz - 48kHz ±0.5dB
DAC typeDelta-Sigma
Time delay< 18ms
Max transmission distance40m (line of sight)
DimensionsDAC : 135 x 70 x 35mm
Transmitter: 73 x 15 x 35mm
Weight380g
Package1x NAD DAC2 and its transmitter
1x Power adapter
1x USB-A to mini-B cable
1x Stereo RCA cable
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rate96kHz
NetworkingYes
Remote ControlN/A
With the NAD DAC2, digital music meets audiophile sound. This simple and highly efficient solution allows you to listen to the music stored on your...
