SMSL B2 DAC Bluetooth 5.1 Receiver
The SMSL B2 is a small, practical, affordable and efficient DAC and Bluetooth receiver. It's based on a CS43131 digital-to-analog conversion chip and a Qualcomm QCC5125 Bluetooth chip, the latter supporting the high-resolution audio codecs aptX, aptX LL, aptX HD and LDAC for quality wireless playback.
3.0 / 5
Reference : 19304
85,00 €tax incl.
70,83 € tax excl.
SMSL B2 DAC Bluetooth 5.1 Receiver CS43131 QCC5125 aptX HD LDAC
SMSL B2: Front view
In addition to its Bluetooth reception, the B2 provides a USB-C format input. Outputs include optical, coaxial and RCA.
The SMSL B2 is clad in a sturdy, sober CNC-machined aluminum chassis, and boasts a handsome 1.9" color LCD display on its front panel, showing the selected input, Bluetooth codec, sampling rate of the file being played, as well as its title and artist.
SMSL B2: Presentation diagram
1Screen
2ON-OFF touch button / source selection
3Bluetooth antenna
4USB input
5Optical input
6Coaxial input
7RCA output
Product typeDAC / Bluetooth receiver
InputsBluetooth 5.0
1x USB-C
Outputs1x Optical Toslink
1x Coaxial
1x Stereo RCA
DAC chipCS43131
Bluetooth chipQCC5125
Bluetooth version5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
THD+N0.0002% (113dB)
Dynamic range128dB
SNR128dB
Output level2Vrms
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (driver required)
Mac OSX10.6+
Linux
Supported sampling ratesPCM up to 24bit 96kHz (LDAC Bluetooth)
PCM up to 24bit 48kHz (USB)
Consumption< 1W
Standby consumption< 0.1W
Dimensions150 x 128 x 39mm
Weight90g
Package1x SMSL B2
1x Bluetooth antenna
1x USB-C to USB-A cable
SMSL B2: Distortion measurement (Bluetooth) SMSL B2: Distortion measurement (USB) SMSL B2: Distortion measurement (digital output) SMSL B2: SNR measurement
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipCS43131
Max sampling rate96kHz
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Testé ce jour
Fonctionne bien après un appairage rapide et sans histoire mais mériterait d'avoir un réglage d'intensité sur l'écran et surtout est arrivé avec le port optique HS (Led rouge éteinte).
Ayant le choix entre optique et coax, j'ai heureusement pu prendre cette solution.
Petit défaut de contrôle en fin de chaine ??
Contactez mes collaborateurs du SAV via les formulaires du site, il est anormal que toutes les sorties ne soient pas fonctionnelles en sortie de boite.
Ils feront rapidement le nécessaire.
This review has been posted for SMSL B2 DAC Bluetooth 5.1 Receiver CS43131 QCC5125 aptX HD LDAC
The SMSL B2 is a small, practical, affordable and efficient DAC and Bluetooth receiver. It's based on a CS43131 digital-to-analog conversion...
