TOPPING D10 USB DAC 32bit/384kHz DSD 256 XMOS U208 ES9018K2M
The DAC USB TOPPING D10 includes all the on-board components to make high quality HD music. Featuring a USB Xmos U208 USB input, a DAC ESS SABRE ES9018K2M, AOP OPA2134 on DIP 8 media, they offer great services at a reasonable price. A clever product that will find its place next to a desktop or laptop.
Strengths:
  • USB XMOS U208 high-performance USB XMOS U208 high-performance
  • Analog output with AOP 2134 on DIP 8 support
  • Optical and coaxial SPDIF digital output
  • Readable display with PCM and DSD sample display
  • Ideal with PA3 Topping Amp
4.9 / 5
Reference : 12596
89,00 €tax incl.
74,17 € tax excl.
This model has been replaced by its big brother, the Topping D10S DAC ES9038Q2M.
Topping d10
32bit 384khz ES9018K2M DAC
Musical and well built
The DAC TOPPING D10 offers high quality manufacturing at a reasonable price. Based on proven circuit boards it provides a lot of music in a well finished compact aluminum case. It can also be used as a USB to SPDIF digital interface thanks to its two optical and coaxial outputs.
USB XMOS U208 and quality components
The D10 features premium components such as a USB XMos U208 USB input, a DAC Es9018K2M and OPA2134 stereo AOP TIs on interchangeable DIP 8 media. This DAC features THESYCON drivers optimized for Windows offering better native DSD compatibility, which makes it an obvious choice for lovers of High Definition.
Technical specifications
Resolution32bit 384kHz
Digital ouptut0.5V p-p (75Ω Coaxial) / 19dB on Toslink
DHT0.003% sur 20 à 20kHz weighted
frequency response20 à 20kHz +/- 0.1dB
Stereo voltage output2V (RCA)
DNR115dB
Internal clock100MHz Clock
Digital input and output
USB InputPCM 44.1kHz - 384kHz 16-32bits
USB DSD frequnecyDSD64 à DSD256 ( DOP - natif )
SPDIF Coaxial output24bits max 44.1kHz - 192kHz
SPDIF Optical output24bits max 44.1kHz - 192kHz
USB compatibilityWindows 7, 8, 8.1, 10 (nécessite un driver) Mac OS 10 et Linux
Divers
Power needed5V 2A on USB port
Dimensions146 x 103 x 37mm
weight407g
Accessorys1x cable USB
InputJack 2.5mm
InputJack 6.35mm
InputACSS
InputType G Main Plug
InputScrew terminals
InputHDMI
InputDIN 5
InputXH 2.54mm
InputType I Main Plug
InputAES/EBU
InputI2S via HDMI
InputIEC C14
InputS/PDIF
InputI2S
InputJack DC 5.5/2.1mm
InputMMCX
InputI2S via RJ45
InputIEC C8
InputSATA
InputPCI
InputJack 3.5mm
InputLightning
InputType C Main Plug
InputJack DC 5.5/2.5mm
InputRJ45
InputOptical Fiber
InputXLR
InputSD Card
InputType A Main Plug
InputGPIO
InputPhono
InputSpeaker terminals
InputPH 2.0mm
InputPCI Express
InputMIDI
InputBNC
InputIEC C16
InputI2C
InputI2S
InputJack DC 3.4/1.4mm
InputWiFi
InputType E / F Main Plug
InputOptical Mini-Toslink
InputMicro SD
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate384kHz
Max sampling rateDSD128
17 reviews
I needed something to reproduce liquid music to my Revox system (a76, a77 & a78). I used an old asus vc60 with Daphile streaming music out of its 3.5mm jack. When this DAC arrived it changed my world! I am no audiophile and I lack in the correct vocabulary, so I'll say that its like watching a poster when you were used to look at a postcard. Everything sound bigger (not louder, but wider), sounds are more clear and distinguishable. To me it's a new listening experience. Very good product, I'm afraid I cannot listen to music without it from now on!
This review has been posted for TOPPING D10 USB DAC 32bit/384kHz DSD 256 XMOS U208 ES9018K2M
Topping D10 USB DAC
Have received this USB D10 DAC today, shipping was then delayed due to corona virus, but the wait can withstand one as long as waiting for an exciting product.
This is my first DAC, and based on what I've read and recommendations, it should be a good DAC to begin with.
The shipment was well packed, no hint of damage etc. So thank you for the deal.
With regards.
Excellent remplaçant du AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023 / ES9023 TCXO
Possesseur du DAC Audiophonics U-Sabre mentionné dans le titre, je regrettais de ne pouvoir lire directement certains fichiers audio en 24/192 et des iso de DSD, j'ai donc opté pour ce nouveau dac. En première écoute en mode PCM, il me semble que le son est plus clair, aéré que ce soit sur du Flac 44.1/16 ou 24/96 avec des morceaux que je connais bien. Je me suis penché suer la possibilité de lecture en direct des DSD.
Il faut d'abord récupérer le driver ASIO Topping sur leur site :
http://www.tpdz.net/newsinfo/374859.html
Le fichier contient toute la procédure en anglais ainsi que les fichiers nécessaires (Driver ASIO, composants Foobar 2000)
Avec Foobar 2000 , les réglages sont :
File - Preferences - Output - ASIO : foo-dsd-asio
Double clic sur foo_dsd_asio pour l'accès aux réglages supplémentaires:
ASIO Driver : Topping USB Audio Driver
DSD Playback Method : ASIO native
DSD to DSD : None Fs DSD 128
PCM to DSD: SDM Type D Fs DSD 128
DSD/PCM Transitions 50ms
Un point important est de configurer le volume en cliquant sur le panneau de contrôle Topping USB audio device dans la barre des tâches Windows, onglet Volume puis bouton Output et enfin positionner le curseur Master tout en haut (0 dB) sinon vous aurez droit à un bruit ignoble au lieu de la musique.
Le contrôle de volume ne peut se faire que par foobar, tous les autres controle windows sont désactivé.
Merci Audiophonics pour ce super petit DAC !
Excellent produit
Très bon produit, facile a installer entre mon PC sous Windows et ma chaine Hifi.
Très bon son. Je vais pouvoir enfin écouter ma collection de fichiers FLAC avec le lecteur Foobar2000 !
Excellent rapport qualité/prix
Un appareil bien fini, sans fioriture qui donne un son agréable et détaillé à la sortie de mon petit PC sous Linux.
Que demander de plus ?
The DAC USB TOPPING D10 includes all the on-board components to make high quality HD music. Featuring a USB Xmos U208 USB input, a DAC ESS SABRE...
