This model has been replaced by its big brother, the Topping D10S DAC ES9038Q2M.
32bit 384khz ES9018K2M DAC
The DAC TOPPING D10 offers high quality manufacturing at a reasonable price. Based on proven circuit boards it provides a lot of music in a well finished compact aluminum case. It can also be used as a USB to SPDIF digital interface thanks to its two optical and coaxial outputs.
The D10 features premium components such as a USB XMos U208 USB input, a DAC Es9018K2M and OPA2134 stereo AOP TIs on interchangeable DIP 8 media. This DAC features THESYCON drivers optimized for Windows offering better native DSD compatibility, which makes it an obvious choice for lovers of High Definition.
Spécifications | |
Resolution | 32bit 384kHz |
Digital ouptut | 0.5V p-p (75Ω Coaxial) / 19dB on Toslink |
DHT | 0.003% sur 20 à 20kHz weighted |
frequency response | 20 à 20kHz +/- 0.1dB |
Stereo voltage output | 2V (RCA) |
DNR | 115dB |
Internal clock | 100MHz Clock |
Digital input and output | |
USB Input | PCM 44.1kHz - 384kHz 16-32bits |
USB DSD frequnecy | DSD64 à DSD256 ( DOP - natif ) |
SPDIF Coaxial output | 24bits max 44.1kHz - 192kHz |
SPDIF Optical output | 24bits max 44.1kHz - 192kHz |
USB compatibility | Windows 7, 8, 8.1, 10 (nécessite un driver) Mac OS 10 et Linux |
Divers | |
Power needed | 5V 2A on USB port |
Dimensions | 146 x 103 x 37mm |
weight | 407g |
Accessorys | 1x cable USB |
Input | PCI Express |
Input | MIDI |
Input | BNC |
Input | IEC C16 |
Input | I2C |
Input | I2S |
Input | Jack DC 3.4/1.4mm |
Input | RCA |
Input | WiFi |
Input | Type E / F Main Plug |
Input | Optical Mini-Toslink |
Input | Micro SD |
Input | ACSS |
Input | Jack 2.5mm |
Input | Jack 6.35mm |
Input | Type G Main Plug |
Input | Screw terminals |
Input | HDMI |
Input | DIN 5 |
Input | XH 2.54mm |
Input | SPDIF |
Input | Type I Main Plug |
Input | AES/EBU |
Input | I2S via HDMI |
Input | IEC C14 |
Input | S/PDIF |
Input | I2S |
Input | Jack DC 5.5/2.1mm |
Input | MMCX |
Input | USB |
Input | I2S via RJ45 |
Input | IEC C8 |
Input | SATA |
Input | Bluetooth |
Input | Lightning |
Input | PCI |
Input | Jack 3.5mm |
Input | Type C Main Plug |
Input | Jack DC 5.5/2.5mm |
Input | RJ45 |
Input | SD Card |
Input | Optical Fiber |
Input | XLR |
Input | Type A Main Plug |
Input | GPIO |
Input | Phono |
Input | Speaker terminals |
Input | PH 2.0mm |
Input | Optical |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | RCA |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Black |
Average votes 4.9 / 5 17 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Emanuele Davide Ludovico G.
Helge V.
Jean-luc C.
DENIS G.
Paul D.
