This model has been replaced by its big brother, the Topping D10S DAC ES9038Q2M.
32bit 384khz ES9018K2M DAC
The DAC TOPPING D10 offers high quality manufacturing at a reasonable price. Based on proven circuit boards it provides a lot of music in a well finished compact aluminum case. It can also be used as a USB to SPDIF digital interface thanks to its two optical and coaxial outputs.
The D10 features premium components such as a USB XMos U208 USB input, a DAC Es9018K2M and OPA2134 stereo AOP TIs on interchangeable DIP 8 media. This DAC features THESYCON drivers optimized for Windows offering better native DSD compatibility, which makes it an obvious choice for lovers of High Definition.
| Spécifications | |
| Resolution | 32bit 384kHz |
| Digital ouptut | 0.5V p-p (75Ω Coaxial) / 19dB on Toslink |
| DHT | 0.003% sur 20 à 20kHz weighted |
| frequency response | 20 à 20kHz +/- 0.1dB |
| Stereo voltage output | 2V (RCA) |
| DNR | 115dB |
| Internal clock | 100MHz Clock |
| Digital input and output | |
| USB Input | PCM 44.1kHz - 384kHz 16-32bits |
| USB DSD frequnecy | DSD64 à DSD256 ( DOP - natif ) |
| SPDIF Coaxial output | 24bits max 44.1kHz - 192kHz |
| SPDIF Optical output | 24bits max 44.1kHz - 192kHz |
| USB compatibility | Windows 7, 8, 8.1, 10 (nécessite un driver) Mac OS 10 et Linux |
| Divers | |
| Power needed | 5V 2A on USB port |
| Dimensions | 146 x 103 x 37mm |
| weight | 407g |
| Accessorys | 1x cable USB |
| Input | SATA |
| Input | Bluetooth |
| Input | IEC C8 |
| Input | Jack 3.5mm |
| Input | Lightning |
| Input | PCI |
| Input | Jack DC 5.5/2.5mm |
| Input | RJ45 |
| Input | Type C Main Plug |
| Input | XLR |
| Input | SD Card |
| Input | Optical Fiber |
| Input | GPIO |
| Input | Phono |
| Input | Type A Main Plug |
| Input | Optical |
| Input | Speaker terminals |
| Input | PH 2.0mm |
| Input | MIDI |
| Input | BNC |
| Input | PCI Express |
| Input | I2C |
| Input | I2S |
| Input | IEC C16 |
| Input | RCA |
| Input | WiFi |
| Input | Jack DC 3.4/1.4mm |
| Input | Optical Mini-Toslink |
| Input | Micro SD |
| Input | Type E / F Main Plug |
| Input | Jack 6.35mm |
| Input | ACSS |
| Input | Jack 2.5mm |
| Input | Screw terminals |
| Input | HDMI |
| Input | Type G Main Plug |
| Input | SPDIF |
| Input | DIN 5 |
| Input | XH 2.54mm |
| Input | AES/EBU |
| Input | I2S via HDMI |
| Input | Type I Main Plug |
| Input | I2S |
| Input | IEC C14 |
| Input | S/PDIF |
| Input | MMCX |
| Input | USB |
| Input | I2S via RJ45 |
| Input | Jack DC 5.5/2.1mm |
| Output | RCA |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Max sampling rate | DSD128 |
| Max sampling rate | 384kHz |
| Color | Black |
Average votes 4.9 / 5 17 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Emanuele Davide Ludovico G.
Helge V.
Jean-luc C.
DENIS G.
Paul D.
