FIIO M11 PLUS II Digital Audio Player DAP 2x ES9068AS 2x THX AAA-78 Balanced Bluetooth WiFi AirPlay2 MQA 32bit 768kHz DSD512
FiiO offers with its M11 Plus II a high-end music player, designed to deliver the best sound quality wherever you are. With a flawless design, it embeds high-end audio components in an optimized and intelligent architecture. Complete, practical and versatile, the M11 Plus II is a great fit for any purpose.
Reference : 16477
690,00 €tax incl.
575,00 € tax excl.
FiiO M11 Plus II
FiiO M11 Plus II Baladeur Numérique DAP 2x ES9068AS 2x THX AAA-78 Symétrique Bluetooth WiFi AirPlay2 MQA 32bit 768kHz DSD512
Dual ESS ES9068AS DAC
The digital / analog conversion stage of the M11 Plus II is entrusted to two ESS ES9068AS DAC chips. These allow to deliver a rich, natural and precise sound, while supporting high resolutions, up to 32bit 768kHz and DSD512.
Octa-Core Snapdragon 660 CPU
For fast and efficient data processing, the M11 Plus II uses an octa-core Snapdragon 660 processor, ensuring a smooth experience regardless of usage. In addition, this model provides low power consumption for long battery life.
2x THX AAA-78 Amplification stage
The amplifier stage of the player is powered by a pair of THX AAA-78 chips. They benefit from an error correction technology for a detailed reproduction and a large sound scene.
Anti-interference circuit
The M11 Plus II adopts a new internal architecture based on modular circuits. Each module of the circuit has its own shielding for perfect separation of each section. This design ensures that each part does not interfere with the others for a minimal noise level.
Optimized power supply
This DAP integrates three independent power supplies, in order to provide a large energy supply to the different circuits and to offer consistent power combined with a nice dynamic range. The heat dissipation has also been optimized with numerous measures for maximum stability and durability.
Perfect synchronization, minimum jitter
For this DAP, FiiO has developed its own 4th generation FPGA, integrating the DAPS (Digital audio Purification System) technology. This FPGA works in conjunction with 2 NDK custom clocks for maximum precision and extremely low jitter.
Bi-directional Bluetooth & WiFi
Particularly convenient, the FiiO M11 Plus II takes advantage of bi-directional Bluetooth reception and WiFi with DLNA and AirPlay support for wireless use. The Bluetooth 5.0 chip also supports the aptX HD and LDAC transmission codecs for high quality playback.
Modern geometric design
FiiO has put a lot of work into the design of its Walkman. Marked by a modern geometric aesthetic, it is also optimized for intuitive use, with every button easily accessible at all times.
Intelligent volume
The M11 Plus II's unique intelligent volume system uses a volume knob combined with touchscreen adjustment for precise and comfortable volume level adjustment.
5.5" Screen
Dressed in a beautiful 5.5" IPS touch screen, the M11 Plus II displays beautiful colors. Offering an optimal visual experience, this screen allows you to enjoy an intuitive and easy user experience.
Balanced outputs & USB DAC mode
In addition to its unbalanced output in 3.5mm jack format, the M11 Plus II has balanced outputs in 2.5mm jack and 4.4mm jack format, but also a balanced line output and an unbalanced line output. The device is also usable in USB DAC mode via its USB-C connector.
Adjustable gain
The M11 Plus II provides 3 selectable gain levels. Each gain level has a 120 level adjustable volume. This setting allows the DAP to be used with most headphones on the market, whether they are high impedance or very sensitive in-ear monitors.
Android 10
The M11 Plus LTD runs on a version of Android 10 specially adapted by FiiO for a smooth and intuitive experience. Every detail has been meticulously optimized by the brand for a pleasant use.
With you all day long
With a 6000mAh battery supporting Quick Charge QC2.0/3.0/4.0 and USB-PD technology for fast charging, the M11 Plus II will be able to accompany you all day, on the go or at home. The DAP can be used for 11.5 hours continuously and will last for 41 days on standby.
DSD & MQA
The FiiO DAP supports very high resolution files. It is thus compatible with DSD up to DSD512, but also allows MQA 8x decoding. This last format allows a sound reproduction as close as possible to the quality of the original recordings, with a limited file size.
Product typeDigital Audio PLayer (DAP)
DAC Chip2x ESS ES9068AS
Amplification chip2x THX AAA-78
LPF3x OPA1642
TouchscreenIPS 5.5" 1440x720px
Connectivity / ConnectorsTwo-way USB-C
Two-way Bluetooth
AirPlay2
FiiO Link
WiFi 2.4GHz/5GHz
UpNP
Outputs1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 2.5mm headphone output
1x Balanced Jack 4.4mm headphone output
Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
RAM4GB
StorageROM : 64GB
Expandable via Micro SD (not included)
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
DXD up to 24bit 352.8kHz
MQA
Recommended headphone impedanceSingle-ended output : 16-150Ω
Balanced output : 16-300Ω
EQ10 bands, ±12dB
8 presets
Battery6000mAh
Quick Charge QC4.0 / PD2.0
Single-ended headphone output @ High gain
Output power≥ 300mW @ 16Ω, THD+N < 1%
≥ 210mW @ 32Ω, THD+N < 1%
≥ 33mW @ 300Ω, THD+N < 1%
Output impedance≤ 1Ω
THD+N 0.00054% @ 1kHz, 32Ω
Crosstalk≥ 76dB @ 1kHz, 32Ω
Noise floor≤ 2.5µV (dBA)
SNR≥ 122dB (dBA)
Frequency response20Hz ~ 20kHz (-1dB)
Single-ended line output
THD+N 0.0006% @ 1kHz, 10kΩ
SNR 118dB (dBA)
Frequency response20Hz ~ 50kHz (-0.5dB)
Noise floor 2.5µV (dBA)
Crosstalk 105dB @ 1kHz, 10kΩ
Line out level2V @ 1kHz, 10kΩ
Balanced headphone output @ High gain
Output power≥ 400mW @ 16Ω, THD+N < 1%
≥ 660mW @ 32Ω, THD+N < 1%
≥ 90mW @ 300Ω, THD+N < 1%
Output impedance≤ 2Ω
THD+N 0.00085% @ 1kHz, 32Ω
Crosstalk≥ 111dB @ 1kHz, 32Ω
SNR≥ 126dB (dBA)
Frequency response20Hz ~ 80kHz (-1dB)
Balanced line output
THD+N 0.0004% @ 1kHz, 10kΩ
SNR 125dB (dBA)
Frequency response20Hz - 50kHz (-0.5dB)
Noise floor 2µV (dBA)
Crosstalk 104dB @ 1kHz, 10kΩ
Line out3V @ 1kHz, 10k
Dimensions136.6 x 75.7 x 17.6mm
Weight310g
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputJack 4.4mm
OutputWiFi
OutputJack 2.5mm
OutputBluetooth
DAC / ADC ChipES9068AS
Max sampling rateDSD512
Max sampling rate768kHz
FiiO offers with its M11 Plus II a high-end music player, designed to deliver the best sound quality wherever you are. With a...
