Digital Audio Player DAP 2x ES9068AS 2x THX AAA-78 Balanced Bluetooth WiFi AirPlay2 MQA 32bit 768kHz DSD512
FiiO offers with its M11 Plus II a high-end music player, designed to deliver the best sound quality wherever you are. With a flawless design, it embeds high-end audio components in an optimized and intelligent architecture. Complete, practical and versatile, the M11 Plus II is a great fit for any purpose.
The digital / analog conversion stage of the M11 Plus II is entrusted to two ESS ES9068AS DAC chips. These allow to deliver a rich, natural and precise sound, while supporting high resolutions, up to 32bit 768kHz and DSD512.
For fast and efficient data processing, the M11 Plus II uses an octa-core Snapdragon 660 processor, ensuring a smooth experience regardless of usage. In addition, this model provides low power consumption for long battery life.
The amplifier stage of the player is powered by a pair of THX AAA-78 chips. They benefit from an error correction technology for a detailed reproduction and a large sound scene.
The M11 Plus II adopts a new internal architecture based on modular circuits. Each module of the circuit has its own shielding for perfect separation of each section. This design ensures that each part does not interfere with the others for a minimal noise level.
This DAP integrates three independent power supplies, in order to provide a large energy supply to the different circuits and to offer consistent power combined with a nice dynamic range. The heat dissipation has also been optimized with numerous measures for maximum stability and durability.
For this DAP, FiiO has developed its own 4th generation FPGA, integrating the DAPS (Digital audio Purification System) technology. This FPGA works in conjunction with 2 NDK custom clocks for maximum precision and extremely low jitter.
Particularly convenient, the FiiO M11 Plus II takes advantage of bi-directional Bluetooth reception and WiFi with DLNA and AirPlay support for wireless use. The Bluetooth 5.0 chip also supports the aptX HD and LDAC transmission codecs for high quality playback.
FiiO has put a lot of work into the design of its Walkman. Marked by a modern geometric aesthetic, it is also optimized for intuitive use, with every button easily accessible at all times.
The M11 Plus II's unique intelligent volume system uses a volume knob combined with touchscreen adjustment for precise and comfortable volume level adjustment.
Dressed in a beautiful 5.5" IPS touch screen, the M11 Plus II displays beautiful colors. Offering an optimal visual experience, this screen allows you to enjoy an intuitive and easy user experience.
The M11 Plus II provides 3 selectable gain levels. Each gain level has a 120 level adjustable volume. This setting allows the DAP to be used with most headphones on the market, whether they are high impedance or very sensitive in-ear monitors.
The M11 Plus LTD runs on a version of Android 10 specially adapted by FiiO for a smooth and intuitive experience. Every detail has been meticulously optimized by the brand for a pleasant use.
With a 6000mAh battery supporting Quick Charge QC2.0/3.0/4.0 and USB-PD technology for fast charging, the M11 Plus II will be able to accompany you all day, on the go or at home. The DAP can be used for 11.5 hours continuously and will last for 41 days on standby.
The FiiO DAP supports very high resolution files. It is thus compatible with DSD up to DSD512, but also allows MQA 8x decoding. This last format allows a sound reproduction as close as possible to the quality of the original recordings, with a limited file size.
| Specifications | |
| Product type | Digital Audio PLayer (DAP) |
| DAC Chip | 2x ESS ES9068AS |
| Amplification chip | 2x THX AAA-78 |
| LPF | 3x OPA1642 |
| Touchscreen | IPS 5.5" 1440x720px |
| Connectivity / Connectors | Two-way USB-C Two-way Bluetooth AirPlay2 FiiO Link WiFi 2.4GHz/5GHz UpNP |
| Outputs | 1x Single-ended Jack 3.5mm headphone output 1x Balanced Jack 2.5mm headphone output 1x Balanced Jack 4.4mm headphone output |
| Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
| RAM | 4GB |
| Storage | ROM : 64GB Expandable via Micro SD (not included) |
| Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 DXD up to 24bit 352.8kHz MQA |
| Recommended headphone impedance | Single-ended output : 16-150Ω Balanced output : 16-300Ω |
| EQ | 10 bands, ±12dB 8 presets |
| Battery | 6000mAh Quick Charge QC4.0 / PD2.0 |
| Single-ended headphone output @ High gain | |
| Output power | ≥ 300mW @ 16Ω, THD+N < 1% ≥ 210mW @ 32Ω, THD+N < 1% ≥ 33mW @ 300Ω, THD+N < 1% |
| Output impedance | ≤ 1Ω |
| THD+N | ≤ 0.00054% @ 1kHz, 32Ω |
| Crosstalk | ≥ 76dB @ 1kHz, 32Ω |
| Noise floor | ≤ 2.5µV (dBA) |
| SNR | ≥ 122dB (dBA) |
| Frequency response | 20Hz ~ 20kHz (-1dB) |
| Single-ended line output | |
| THD+N | ≤ 0.0006% @ 1kHz, 10kΩ |
| SNR | ≥ 118dB (dBA) |
| Frequency response | 20Hz ~ 50kHz (-0.5dB) |
| Crosstalk | ≥ 105dB @ 1kHz, 10kΩ |
| Line out level | 2V @ 1kHz, 10kΩ |
| Balanced headphone output @ High gain | |
| Output power | ≥ 400mW @ 16Ω, THD+N < 1% ≥ 660mW @ 32Ω, THD+N < 1% ≥ 90mW @ 300Ω, THD+N < 1% |
| Output impedance | ≤ 2Ω |
| THD+N | ≤ 0.00085% @ 1kHz, 32Ω |
| Crosstalk | ≥ 111dB @ 1kHz, 32Ω |
| SNR | ≥ 126dB (dBA) |
| Frequency response | 20Hz ~ 80kHz (-1dB) |
| Balanced line output | |
| THD+N | ≤ 0.0004% @ 1kHz, 10kΩ |
| SNR | ≥ 125dB (dBA) |
| Frequency response | 20Hz - 50kHz (-0.5dB) |
| Noise floor | ≤ 2µV (dBA) |
| Crosstalk | ≥ 104dB @ 1kHz, 10kΩ |
| Line out | 3V @ 1kHz, 10kΩ |
| General | |
| Dimensions | 136.6 x 75.7 x 17.6mm |
| Weight | 310g |
| Color | Black |
| Input | USB |
| Input | Micro SD |
| Input | Bluetooth |
| Input | WiFi |
| Output | Jack 2.5mm |
| Output | Bluetooth |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| Output | WiFi |
| DAC / ADC Chip | ES9068AS |
| Color | Black |
