DAP HiFi Music Player DAC AK4495 32bit 384kHz DSD128 Blue
The iBasso DX120 is a high-end digital music player (DAP) that delivers high-flying audio performance thanks to its clever design. DAC AK4495, USB XMOS XU208, Quad Core CPU, dual PLL / TCXO clock and fast charging make this DX120 an ideal companion for your listening sessions at home or on the go.
A large part of the development of the DX120 was to get the most out of the DAC AK4495 chip. The specifications of this chip display a THD+N at -105dB. In practice, it is quite difficult to achieve such a value. The engineers at iBasso have therefore worked on the design of a unique design, allowing to reach a THD+N of -111dB !
For its amplification section, the DX120 uses one AOP per channel, with a fully symmetrical output scheme. Thus, the output in 2.5mm symmetrical Jack format combined with the careful architecture of the DAP ensure low distortion and crosstalk.
To ensure an extremely low jitter, the DX120 integrates a combo of PLL and TCXO clocks. The phase noise reaches a value of -145dBc/Hz, the jitter is brought to <=35ps and the frequency stability is less than 1ppm for a sound reproduction of great transparency and precision.
The internal design of this DAP allows it to be used with a wide range of headsets and IEMs, including demanding models. Indeed, it offers a power of 400mW for a load of 32 Ohm and an impressive restitution of low frequencies.
The iBasso DX120 features carefully selected components. Underneath its robust aluminium shell is a DAC AK4495 chip that supports high sampling rates, with PCM up to 32bit 384kHz and native DSD128. This chip is combined with a high-performance USB XMOS XU208 interface, a BQ25890 MaxCharge TI chip for device charge management and ultra-fast charging, and finally the PLL and TCXO clock combo for perfect signal synchronization.
The DAC therefore incorporates components that allow it to charge its battery extremely quickly. It supports both MTK-PE and QC2.0 technologies. It is thus possible to recharge the DX120 at 12V or 9V 1.5A, while remaining compatible with a more conventional 5V charge. These technologies allow a complete charge in only 2 hours, and then enjoy many hours of reading.
The DX120 is equipped with a beautiful 3.2" touch screen for a 480*800px resolution. As an IPS slab, it has high contrast, high brightness and above all wide viewing angles, allowing comfortable use, even in daylight and outdoors.
The iBasso player carries the brand's latest operating system: Mango OS. It is still based on Linux but has been largely optimized and specially designed for portable audio systems. A GPU and Open GL technology have also been implemented in the device to relieve the CPU and ensure smooth navigation. In addition, the DMA (Direct Memory Access) process is used to quickly perform background tasks without cluttering the CPU unnecessarily. This gives the CPU more free computing power to decode audio files.
The iBasso DX120's Jack outputs are not compatible with headphones and headphones with a TRRS Jack connector (3 separations on the Jack, for microphone or built-in volume control). If you have headphones or headphones with TRRS jack, it is necessary to use an adapter (sold separately, available as an accessory).
| Specifications | |
| Product type | DAP |
| OS | Mango OS |
| DAC | AK4495 |
| Outputs | 1x Balanced Jack 2.5mm 1x Single-Ended Jack 3.5mm 1x Line Out Jack 3.5mm 1x Coaxial |
| Screen | Écran IPS capacitif 3.2" 480*800px |
| Sampling rate | PCM up to 32bit 384kHz Native DSD up to DSD128 |
| System clock | TCXO and PLL |
| USB DAC Function | USB XMOS XU208 Interface, USB Thesycon driver |
| Storage | SHDC and SDXC up to 2TB (not included) |
| Output voltage | Balanced Jack 2.5mm : 3.6Vrms Single-Ended Jack 3.5mm : 1.8Vrms Line Out Jack 3.5mm : 1.8Vrms |
| Frequency response | Balanced Jack 2.5mm : 10Hz-45kHz +/-1dB Single-Ended Jack 3.5mm : 10Hz-45kHz +/-1dB Line Out Jack 3.5mm: 10Hz-45kHz +/-1dB |
| THD+N | Balanced Jack 2.5mm : 0.00028%, -111dB (without load) / 0.00032%, -110dB (32 Ohm @ 2.4Vrms) Single-Ended Jack 3.5mm : 0.00042%, -107dB (without load) / 0.00056%, -105dB (32 Ohm @ 1.2Vrms) Line Out Jack 3.5mm : 0.00042%, -107dB (without load) |
| DNR | Balanced Jack 2.5mm : 117dB Single-Ended Jack 3.5mm : 115dB Line Out Jack 3.5mm : 115dB |
| SNR | Balanced Jack 2.5mm : 117dB Single-Ended Jack 3.5mm : 115dB Line Out Jack 3.5mm : 115dB |
| Crosstalk | Balanced Jack 2.5mm : -116dB Single-Ended Jack 3.5mm : -115dB |
| Output impedance | Balanced Jack 2.5mm : 0.36 Ohm Single-Ended Jack 3.5mm : 0.24 Ohm |
| General | |
| Autonomy | 16h in playback |
| Battery | 3.8V 3700mAh Li-Polymer |
| Quick Charge | Quick Charge 2.0 / MTK-PE |
| Dimensions | 63 x 113 x 15mm |
| Weight | 165g |
| Color | Blue |
| Package | 1x iBasso DX120 1x Protection case 1x Screen protector 1x USB-C Cable 1x Coaxial Câble |
| Input | Micro SD |
| Output | Jack 3.5mm |
| Output | Jack 2.5mm |
| DAC / ADC Chip | AK4495 |
| Max sampling rate | DSD128 |
| Max sampling rate | 384kHz |
| Color | Blue |
| Color | Other |
