By buying this product you get 345 loyalty points
IBasso is releasing the magnificent DX320 MAX TI in a limited edition of only 888 copies worldwide! This brand new version reveals a different appearance, a compact design but which inspires robustness and elegance thanks to numerous manufacturing details.
For the rest, the DX320 MAX TI uses the excellent internal architecture of the standard version and X edition but this time with the use of 4x BD34301EKV DACs. A high-end digital music player, the iBasso DX320 MAX TI thus has an extremely neat design, designed to offer the best sound performance for an exceptional musical experience. Powerful and feature-rich, the DX320 MAX TI is the perfect companion for listening at home or on the go.
No less than four RHOM BD34301EKV DACs equip the digital/analog conversion stage of the iBasso DX320 MAX TI, for a total of 4 conversion channels. These combined channels allow the DAP to have a fully balanced conversion circuit while promoting its sound performance.
The DX320 MAX TI conceals in its heart an FPGA-Master specifically designed for these models. Its role is to recover the audio data sent by the SoC in order to maintain a clean and stable signal. Combined with two Accusilicon femtosecond clocks, it generates and perfectly synchronizes clock signals. In short, it ensures a drastic reduction in jitter to provide an extremely clean digital audio signal.
The integrated Qualcomm Snapdragon 660 8-core processor, engraved in 14nm, offers incredible power to efficiently process audio signals while allowing fluid navigation within the interface of the device. This SoC is associated with 6GB of RAM and a storage space (ROM) of 128GB (expandable via Micro SD card not supplied).
The power stage of the DX320 MAX TI incorporates two independent batteries. The first is responsible for powering the digital stage, where the second propels the headphone amplifier. This separation of the power supplies makes it possible in particular to limit possible interference between the digital and analog circuits in order to attenuate the level of distortion as much as possible.
In addition, the amplification section is powered by a +/- 8.4V battery. No voltage amplification is used which guarantees pure and maximum current output. An optimized Class A discrete amplifier circuit then eliminates transistor switching distortion and heat generation.
Perfectionist, the iBasso brand after much research has succeeded in miniaturizing the concept of the multi-stage potentiometer generally present on high-end amplifiers for integration into its DX320 MAX TI portable DAP. This makes it possible to adjust the volume without the appearance of noise and to control the sound of the channels with only a difference of almost +/-0.1dB.
Product type | Digital music player (DAP) |
System | Android 11 + Mango s |
Inputs | 1* Slot Micro SD (SDXC and SDHC - Micro SD 2 To) |
Outputs | 1* Single-ended Jac 3.5mm 1* Balanced Jack 4.4mm 1* Mini Coaxial (PCM up to 24bit 384kHz and DoP up to DSD128) 1* USB-C (PCM up to 32bit 384kHz, Native DSD up to DSD256 and DoP up to DSD128) |
Output levels | Balanced: 9Vrms Single-ended: 4.5Vrms |
USB functions | 3.1 SuperSpeed transfer USB DAC (PCM up to 32bit 384kHz and DoP up to DSD128) |
Connectivity | 5G WiFi Bluetooth 5.0 |
DAC chip | 4x RHOM BD34301EKV |
FPGA | |
RAM | 6Go |
ROM (Stockage) | 128Go |
Touchscreen | 5.0" IPS Screen 1080*1920px |
Physical gain control | 4 settings |
Loading time | Analog section : 2h Digital section : 3h |
Autonomy | 17h in normal mode 13h in ultimate mode |
Supported audio formats | MQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DSD512 |
Power supply | DC 12V |
Body material | Metal alloy |
Color | Silver |
Weight | 620g |
Dimensions | 146*86*30mm |
Input | WiFi |
Input | USB |
Input | Micro SD |
Input | Bluetooth |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Output | USB |
Output | Coaxial SPDIF |
DAC / ADC Chip | ROHM BD34301EKV |
Max sampling rate | MQA |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Silver |
