IBASSO DX320 MAX TI Digital Audio Player DAP Balanced 4x BD34301EKV Bluetooth 5.0 WiFi 5G 32bit 768kHz DSD512 MQA
IBasso is releasing the magnificent DX320 MAX TI in a limited edition of only 888 copies worldwide! This brand new version reveals a different appearance, a compact design but which inspires robustness and elegance thanks to numerous manufacturing details. For the rest, the DX320 MAX uses the excellent internal architecture of the standard version and X edition but this time with the use of 4x BD34301EKV DACs. A high-end digital music player, the iBasso DX320 MAX thus has an extremely neat design, designed to offer the best sound performance for an exceptional musical experience.
By buying this product you get 359 loyalty points
Reference : 17681
3 590,00 €tax incl.
2 991,67 € tax excl.
iBasso DX320 MAX TI
IBASSO DX320 MAX TI Baladeur Numérique DAP Symétrique 4x BD34301EKV Bluetooth 5.0 WiFi 5G MQA
For the rest, the DX320 MAX TI uses the excellent internal architecture of the standard version and X edition but this time with the use of 4x BD34301EKV DACs. A high-end digital music player, the iBasso DX320 MAX TI thus has an extremely neat design, designed to offer the best sound performance for an exceptional musical experience. Powerful and feature-rich, the DX320 MAX TI is the perfect companion for listening at home or on the go.
Quadruple DAC ROHM BD34301EKV
No less than four RHOM BD34301EKV DACs equip the digital/analog conversion stage of the iBasso DX320 MAX TI, for a total of 4 conversion channels. These combined channels allow the DAP to have a fully balanced conversion circuit while promoting its sound performance.
FPGA Master
The DX320 MAX TI conceals in its heart an FPGA-Master specifically designed for these models. Its role is to recover the audio data sent by the SoC in order to maintain a clean and stable signal. Combined with two Accusilicon femtosecond clocks, it generates and perfectly synchronizes clock signals. In short, it ensures a drastic reduction in jitter to provide an extremely clean digital audio signal.
Qualcomm Snapdragon 660 processor
The integrated Qualcomm Snapdragon 660 8-core processor, engraved in 14nm, offers incredible power to efficiently process audio signals while allowing fluid navigation within the interface of the device. This SoC is associated with 6GB of RAM and a storage space (ROM) of 128GB (expandable via Micro SD card not supplied).
Dual battery and own power supply for the AMP section
The power stage of the DX320 MAX TI incorporates two independent batteries. The first is responsible for powering the digital stage, where the second propels the headphone amplifier. This separation of the power supplies makes it possible in particular to limit possible interference between the digital and analog circuits in order to attenuate the level of distortion as much as possible.
In addition, the amplification section is powered by a +/- 8.4V battery. No voltage amplification is used which guarantees pure and maximum current output. An optimized Class A discrete amplifier circuit then eliminates transistor switching distortion and heat generation.
Multi-stage potentiometer for volume adjustment
Perfectionist, the iBasso brand after much research has succeeded in miniaturizing the concept of the multi-stage potentiometer generally present on high-end amplifiers for integration into its DX320 MAX TI portable DAP. This makes it possible to adjust the volume without the appearance of noise and to control the sound of the channels with only a difference of almost +/-0.1dB.
Product typeDigital music player (DAP)
SystemAndroid 11 + Mango s
Inputs1* Slot Micro SD (SDXC and SDHC - Micro SD 2 To)
Outputs1* Single-ended Jac 3.5mm
1* Balanced Jack 4.4mm
1* Mini Coaxial (PCM up to 24bit 384kHz and DoP up to DSD128)
1* USB-C (PCM up to 32bit 384kHz, Native DSD up to DSD256 and DoP up to DSD128)
Output levelsBalanced: 9Vrms
Single-ended: 4.5Vrms
USB functions3.1 SuperSpeed transfer
USB DAC (PCM up to 32bit 384kHz and DoP up to DSD128)
Connectivity5G WiFi
Bluetooth 5.0
DAC chip4x RHOM BD34301EKV
FPGA
RAM6Go
ROM (Stockage)128Go
Touchscreen5.0" IPS Screen
1080*1920px
Physical gain control 4 settings
Loading timeAnalog section : 2h
Digital section : 3h
Autonomy17h in normal mode
13h in ultimate mode
Supported audio formatsMQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DSD512
Power supplyDC 12V
Body materialMetal alloy
ColorSilver
Weight620g
Dimensions146*86*30mm
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputJack 4.4mm
OutputUSB
OutputCoaxial SPDIF
DAC / ADC ChipROHM BD34301EKV
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
IBasso is releasing the magnificent DX320 MAX TI in a limited edition of only 888 copies worldwide! This brand new version reveals a different...
