SHANLING M3 ULTRA Digital Audio Player DAP 2x ES9219C 2x RT6863 Android 10 Bluetooth 5.0 32bit 384kHz DSD256 MQA Black
The M3 Ultra is Shanling's latest portable high-definition digital music player, following the excellent M3X. It uses the same architecture as the M3X with an improved processor, a newer Android version and many additional features. Its digital/analog conversion stage is based on a pair of ES9219C chips and its amplification section uses two independent TR6863 chips. It thus offers a sound reproduction of great precision and musicality, as well as a fluid user experience.
Reference : 16986
469,00 €tax incl.
390,83 € tax excl.
Shipping date: 15-05-2025.
Shanling M3 Ultra black
Shanling M3 Ultra Baladeur Numérique DAP 2x ES9219C 2x RT6863 Android 10 Bluetooth 5.0 32bit 384kHz DSD256 MQA
Dual ES9219C DAC
The Shanling M3 Ultra is equipped with two ESS ES9219C 32bit chips. In addition to ensuring clear and detailed sound reproduction, these chips allow the DAP to decode high-resolution PCM audio streams up to 32bit 768kHz and Native DSD up to DSD256. They also offer the possibility to play MQA (Master Quality Authenticated) format for a sound as close as possible to the studio recording.
New amplification circuit
Shanling's DAP delivers comfortable power thanks to a high-performance amplifier circuit. The latter is equipped with two independent RT6863 chips, capable of supporting many headphones on the market while ensuring low noise and distortion.
8-core Snapdragon processor
The M3 Ultra provides ultra-smooth operation thanks to its Snapdragon 665 processor, which allows you to navigate the interface and access your music without latency for a comfortable experience.
Android 10
The integrated Android 10 operating system, in addition to an intuitive interface, allows access to many applications. Thus, you will be able to enjoy your favorite music streaming applications.
Bluetooth 5.0
With its Bluetooth 5.0 chip, the M3 Ultra allows for bi-directional transmission, enabling it to receive an audio stream from a smartphone as well as send it to a Bluetooth headphone for example. It also supports the high resolution LDAC codec.
A consequent autonomy
With its 3500mAh battery, the M3 Ultra offers up to 20.5 hours of battery life. It also supports the QC3.0 18W fast charging protocol.
Product typeDAP
DAC chip2* ES9219C
Amplification chip2* RT6863
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
ConnectivityWiFi dual band
Bluetooth 5.0
CPUSnapdragon 665 8 cores
RAM3GB
ROM32GB
Screen4.2" 1200*768px
Output impedance< 1Ω
Battery3500mAh
Battery lifeUp to 20.5h
OSAndroid 10
MQA
Headphone output power260mW @ 32Ω
InputMicro SD
OutputBluetooth
OutputJack 4.4mm
OutputWiFi
OutputJack 3.5mm
DAC / ADC ChipES9219C
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
The M3 Ultra is Shanling's latest portable high-definition digital music player, following the excellent M3X. It uses the same architecture as...
