Digital Audio Player DAP 2x ES9219C 2x RT6863 Android 10 Bluetooth 5.0 32bit 384kHz DSD256 MQA
The M3 Ultra is Shanling's latest portable high-definition digital music player, following the excellent M3X. It uses the same architecture as the M3X with an improved processor, a newer Android version and many additional features. Its digital/analog conversion stage is based on a pair of ES9219C chips and its amplification section uses two independent TR6863 chips. It thus offers a sound reproduction of great precision and musicality, as well as a fluid user experience.
The Shanling M3 Ultra is equipped with two ESS ES9219C 32bit chips. In addition to ensuring clear and detailed sound reproduction, these chips allow the DAP to decode high-resolution PCM audio streams up to 32bit 768kHz and Native DSD up to DSD256. They also offer the possibility to play MQA (Master Quality Authenticated) format for a sound as close as possible to the studio recording.
Shanling's DAP delivers comfortable power thanks to a high-performance amplifier circuit. The latter is equipped with two independent RT6863 chips, capable of supporting many headphones on the market while ensuring low noise and distortion.
The M3 Ultra provides ultra-smooth operation thanks to its Snapdragon 665 processor, which allows you to navigate the interface and access your music without latency for a comfortable experience.
The integrated Android 10 operating system, in addition to an intuitive interface, allows access to many applications. Thus, you will be able to enjoy your favorite music streaming applications.
With its Bluetooth 5.0 chip, the M3 Ultra allows for bi-directional transmission, enabling it to receive an audio stream from a smartphone as well as send it to a Bluetooth headphone for example. It also supports the high resolution LDAC codec.
With its 3500mAh battery, the M3 Ultra offers up to 20.5 hours of battery life. It also supports the QC3.0 18W fast charging protocol.
Product type | DAP |
DAC chip | 2* ES9219C |
Amplification chip | 2* RT6863 |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
Connectivity | WiFi dual band Bluetooth 5.0 |
CPU | Snapdragon 665 8 cores |
RAM | 3GB |
ROM | 32GB |
Screen | 4.2" 1200*768px |
Output impedance | < 1Ω |
Battery | 3500mAh |
Battery life | Up to 20.5h |
OS | Android 10 |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 MQA |
Headphone output power | 260mW @ 32Ω |
Color | Green |
Input | Micro SD |
Output | Jack 3.5mm |
Output | Bluetooth |
Output | Jack 4.4mm |
Output | WiFi |
DAC / ADC Chip | ES9219C |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Max sampling rate | MQA |
Color | Green |
