By buying this product you get 165 loyalty points
This product has been replaced by the new version, the SHANLING M9 Digital Audio Player 2x AKM AK4499.
Digital Audio Player DAP 2x AK4499EQ XMOS Bluetooth 5.0 WiFi 32bit 768kHz DSD512
Resolutely high-end, the Shanling M8 portable music player benefits from an exceptional design thanks to the use of high-performance high-end components. In particular, it uses a pair of AKM AK4499EQ DACs, an XMOS XUF208 USB interface and a Qualcomm CSR8675 Bluetooth receiver.
The M8 uses Shanling AGLO technology, for Android Global Lossless Output. This technology allows you to enjoy an Android OS, without having to pay for the inherent system processing that could degrade the sound quality.
The main originality of this M8 is its system of interchangeable jack connectors. This one allows you to take advantage of all common balanced and unbalanced jack connections, without using an external adapter.
The analog circuitry of the M8 uses two high-performance AKM AK4499EQ DAC chips with integrated I/V conversion stage and balanced amplifier. This architecture provides rich and accurate sound reproduction.
The USB connector is associated with a latest-generation XMOS XUF208 interface, supporting high-resolution files up to PCM 32bit 768kHz and DSD512 Native.
Featuring Bluetooth 5.0 connectivity, the Shanling M8 is equipped with a Qualcomm CSR8675 receiver chip. It supports LDAC, LHDC and aptX HD codecs for high-quality sound reproduction in Bluetooth.
Particularly powerful and fast, the M8 is powered by a Snapdragon 430 Octa-Core processor and 4GB of RAM. This combination ensures smooth operation. A 64GB storage space is also integrated, expandable with a Micro SD card (not included).
The Shanling M8 takes advantage of the Shanling OP+BUF amplification architecture in an even more improved and optimized version. This version provides more power, better measurements and superior sound quality.
In order to take advantage of the full potential of the DAC AK4499EQ chips, Shanling's engineers worked particularly hard on the I/V conversion stage. Each element of the circuit is thus optimized and precisely adjusted to offer exceptional sound quality.
With three gain settings, the M8 can accommodate a wide range of headphones, from high-sensitivity earphones to extremely demanding headphones.
The magnificent M8 chassis is CNC machined with extreme precision from a single block of aluminum. This allows for a particularly solid construction, while providing additional shielding.
The M8 uses a graphite cooling system to efficiently dissipate heat from the DAP components to the aluminum chassis.
With a large 7000mAh battery, the Shanling M8 offers a long autonomy, up to 14 hours in continuous playback. The Qualcomm Quick Charge 3.0 system allows it to quickly recharge the DAP.
The front of the M8 features a stunning 5" Full HD touch screen. This allows intuitive navigation through the device's menus for a smooth user experience.
Enjoy high transfer speeds and smooth streaming with 5G WiFi support and MU-MIMO technology. The M8 also supports file transfer via WiFi, SyncLink remote control, DLNA, AirPlay, and OTA updates.
The M8 offers 6 digital filters, allowing you to adjust the DAP sound signature to suit your listening experience without loss of quality. The unit also provides an equalizer to make more precise adjustments.
The M8's Prime Mode allows for distraction-free operation, turning it into a pure audio player. No more notifications to disturb you while you listen.
Product type | DAP |
DAC Chips | 2x AKM AK4499EQ |
Bluetooth chip | Qualcomm CSR8675 |
Screen | 5" 1080*1920px Touchscreen |
OS | Open Android 7.1 |
File formats | DSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, ACC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8 |
Sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
Gain | Low High Turbo |
Digital filters | 6 Filters |
Storage | 64GB integrated Micro SD slot (not included) |
Bluetooth version | 5.0 |
Bluetooth codecs | Transmission: LDAC, LHDC, aptX HD, aptX, SBC Reception: LDAC, LHDC, aptX HD, aptX LL, aptX, AAC, SBC |
Power | Single-ended output: 18mW @ 32Ω, gain faible, 48mW @ 32Ω, gain élevé, 260mW @ 32Ω, gain turbo Balanced output: 71W @ 32Ω, gain faible, 184mW @ 32Ω, gain élevé, 840mW @ 32Ω, gain turbo |
Frequency response | Single-ended output: 20Hz - 40kHz (0.5dB) Balanced output: 20Hz - 40kHz (-0.5dB) |
THD+N | Single-ended output: 0.00089% Balanced output: 0.00085% |
Channel separation | Single-ended output: 75dB @ 32Ω Balanced output: 115dB @ 32Ω |
SNR | Single-ended output: 121dB Balanced output: 123dB |
Dynamic range | Single-ended output: 121dB Balanced output: 123dB |
Noise floor | Single-ended output: > 115dB (1.7µV) Balanced output: >113dB (2.1µV) |
Output impedance | Single-ended output: < 1Ω Balanced output: < 2Ω |
WiFi | 2.4G / 5G SyncLink DLNA AirPlay OTA Upgrades |
Battery | Capacity : 7000mAh Battery life : up to 14h (single-ended) / 9h (balanced) Charge: 5VDC 2A, Quick Charge 3.0 support |
Dimensions | 138 x 80 x 20mm |
Weight | 342g |
Color | Black |
Package | 1x Shanling M8 1x Storage box 1x USB Cable 1x Jack 2.5mm balanced adapter 1x Jack 3.5mm single-ended adapter 1x Jack 3.5mm Pro balanced adapter 1x Jack 4.4mm balanced adapter |
Input | USB |
Input | Bluetooth |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Output | WiFi |
Output | Jack 2.5mm |
Output | Bluetooth |
DAC / ADC Chip | AK4499 |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
