By buying this product you get 279 loyalty points
Digital Audio Player DAP 2x AKM AK4499EQ Bluetooth 5.0 WiFi 256GB 32bit 768kHz DSD512 MQA
Shanling is back with a high-end digital music player, the M9, taking advantage of the best technologies to offer a unique user experience and rich, immersive listening. Powerful, the DAP is based on an Android 10 system, powered by a Qualcomm Snapdragon 665 processor and 8GB of RAM. Ensuring a great fluidity of use, even in multi-tasks, the M9 is also very intuitive. A large storage space of 256GB is also integrated, allowing you to store numerous audio files as well as to download all your favorite applications.
The M9 also benefits from a brand new design, with an impressive 6" 2K LCD screen! A smaller screen is also added in the notch to display basic information like volume, sample rate or time.
The Shanling DAP benefits from the same interchangeable output module as its predecessor, the M8. It allows you to modify the output format to adapt to all types of headphones and offers single-ended 3.5mm jacks as well as balanced 2.5mm and 4.4mm jacks. The gain circuit has been optimized to provide more power, whether balanced or single-ended. An improvement going hand in hand with a more important battery, offering an autonomy of not 18h of reading in single-ended.
The Shanling M9 also benefits from wireless connectivity, with integrated two-way Bluetooth 5.0, supporting aptX, aptX HD, LHDC and LDAC codecs, as well as WiFi with AirPlay and DLNA compatibility.
This model of the M9 is a limited version, incorporating a pair of the excellent AKM AK4499EQ DAC. This model offers incredibly accurate and transparent sound reproduction, while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512. The M9 also supports the decoding of MQA (Master Quality Authenticated) files for a sound reproduction as close as possible to the studio recording.
Product type | DAP |
Inputs | 1x Micro SD slot Bluetooth 5.0 WiFi |
Outputs (interchangeable system) | Single-ended Jack 3.5mm 1x Balanced Jack 2.5mm 1x Balanced Jack 4.4mm Bluetooth 5.0 |
Main screen | LCD 6" 2160*1080px with notch |
DAC Chip | 2x AKM AK4499EQ |
Amplifier | ADA610 BUF364A OPA1612 |
Output power | Single-ended : 460mW @ 32Ω Balanced : 920mW @ 32Ω |
Secondary screen | Low-power two-color display in the notch |
OS | Android 10 |
CPU | Qualcomm Snapdragon 665 |
RAM | 8GB |
Storage (ROM) | 256GB |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 MQA 16X |
Supported Bluetooth codecs | SBC, aptX, aptX HD, LHDC, LDAC |
WiFi | 2.4G / 5G DLNA support AirPlay support |
Battery | 8350mAh Quick Charge (QC) 18W support |
Battery life | Single-ended : Up to 18h Balanced : Up to 10h |
Dimensions | 152 x 82 x 22mm |
Weight | 409g |
Color | Gray |
Leather case | Included |
Input | Micro SD |
Input | Bluetooth |
Input | WiFi |
Output | Bluetooth |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
Output | Jack 2.5mm |
DAC / ADC Chip | AK4499 |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Gray |
