SHANLING M9 Digital Audio Player DAP 2x AKM AK4499EQ Bluetooth 5.0 WiFi 256GB 32bit 768kHz DSD512 MQA
Shanling is back with a high-end digital music player, the M9, taking advantage of the best technologies to offer a unique user experience and rich, immersive listening. Powerful, the DAP is based on an Android 10 system, powered by a Qualcomm Snapdragon 665 processor and 8GB of RAM. Ensuring a great fluidity of use, even in multi-tasks, the M9 is also very intuitive. A large storage space of 256GB is also integrated, allowing you to store numerous audio files as well as to download all your favorite applications.
By buying this product you get 279 loyalty points
Reference : 15870
2 799,00 €tax incl.
2 332,50 € tax excl.
Shanling M9
Shanling M9 Baladeur Numérique DAP 2x AKM AK4499EQ Bluetooth 5.0 WiFi 256GB 32bit 768kHz DSD512 MQA
The M9 also benefits from a brand new design, with an impressive 6" 2K LCD screen! A smaller screen is also added in the notch to display basic information like volume, sample rate or time.
The Shanling DAP benefits from the same interchangeable output module as its predecessor, the M8. It allows you to modify the output format to adapt to all types of headphones and offers single-ended 3.5mm jacks as well as balanced 2.5mm and 4.4mm jacks. The gain circuit has been optimized to provide more power, whether balanced or single-ended. An improvement going hand in hand with a more important battery, offering an autonomy of not 18h of reading in single-ended.
The Shanling M9 also benefits from wireless connectivity, with integrated two-way Bluetooth 5.0, supporting aptX, aptX HD, LHDC and LDAC codecs, as well as WiFi with AirPlay and DLNA compatibility.
This model of the M9 is a limited version, incorporating a pair of the excellent AKM AK4499EQ DAC. This model offers incredibly accurate and transparent sound reproduction, while supporting high-resolution streams up to PCM 32bit 768kHz and DSD512. The M9 also supports the decoding of MQA (Master Quality Authenticated) files for a sound reproduction as close as possible to the studio recording.
Product typeDAP
Inputs1x Micro SD slot
Bluetooth 5.0
WiFi
Outputs (interchangeable system)Single-ended Jack 3.5mm
1x Balanced Jack 2.5mm
1x Balanced Jack 4.4mm
Bluetooth 5.0
Main screenLCD 6" 2160*1080px with notch
DAC Chip2x AKM AK4499EQ
AmplifierADA610
BUF364A
OPA1612
Output powerSingle-ended : 460mW @ 32Ω
Balanced : 920mW @ 32Ω
Secondary screenLow-power two-color display in the notch
OSAndroid 10
CPUQualcomm Snapdragon 665
RAM8GB
Storage (ROM)256GB
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
MQA 16X
Supported Bluetooth codecsSBC, aptX, aptX HD, LHDC, LDAC
WiFi2.4G / 5G
DLNA support
AirPlay support
Battery8350mAh
Quick Charge (QC) 18W support
Battery lifeSingle-ended : Up to 18h
Balanced : Up to 10h
Dimensions152 x 82 x 22mm
Weight409g
ColorGray
Leather caseIncluded
InputMicro SD
InputWiFi
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 2.5mm
OutputBluetooth
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorGray
Shanling is back with a high-end digital music player, the M9, taking advantage of the best technologies to offer a unique user experience and...
