XDUOO X2S Digital Audio Player DAP 24bit 192kHz DSD128
xDuoo offers with its X2S a particularly compact and practical digital music player, offering however very good sound performances. Its internal architecture allows it to support high resolution audio streams, up to PCM 24bit 192kHz and DSD128, the decoding being done efficiently by the integrated CPU.
4.3 / 5
Reference : 15245
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 14-05-2026.
xDuoo X2S
xDuoo X2S Baladeur numérique DAP 24bit 192kHz DSD128
xDuoo offers with its X2S a particularly compact and practical digital music player, offering however very good sound performances. Its internal architecture allows it to support high resolution audio streams, up to PCM 24bit 192kHz and DSD128, the decoding being done efficiently by the integrated CPU. The DAP has a nice OLED display on the front panel, allowing to display in real time the information related to the current playback but also to access the different parameters of the device.
To allow you to store your entire music library, the X2S can accept a Micro SD card, with a capacity of up to 128GB (not included).
The X2S amplifier circuitry uses a rail-to-rail AOP, allowing it to develop a nice power reserve to accompany many models of headphones and earphones on the market.
Suitable for all types of listening
Versatile, the X2S adapts to all types of listening, notably thanks to the presence of predefined filters but also a 6-band equalizer, adjustable over a gain range from -6dB to +6dB. It is thus possible to adapt the sound reproduction of the device according to your listening device, your music or your tastes.
OLED screen
The X2S has a beautiful 0.96" OLED screen on the front. This one allows to display in real time the information concerning the audio stream in progress as well as the parameters of the device. This one also allows to navigate in an intuitive way through the menus of the device.
Product typeDigital Audio Player (DAP)
Power output250mW @ 32Ω
Frequency response20Hz - 20kHz (±0.5dB)
Gain+6dB
THD+N0.003% (1Khz)
SNR108dB
Acceptable headphone impedance16~300Ω
Battery800mAh 3.7V
Autonomy> 10h
Charging time< 2h
Supported file formatsDSD : DSD64-DSD128 (DFF, DSF)
APE : 16-24it/44.1-96kHz
FLAC : 16-24it/44.1-192kHz
WAV : 16-24it/44.1-192kHz
AIFF : 16-24it/44.1-192kHz
WMA, MP3, AAC, OGG
Charge voltage5V 1A
Micro SD supportUp to 128Go (not included)
Dimensions6.3 x 4 x 1.5cm
Weight50g
ColorGray
InputMicro SD
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate192kHz
Max sampling rateDSD128
ColorGray
7 reviews
bon son mais...
Le son est bon, mais ce sont les à cotés qui pêchent. l’écran n'est pas très lumineux e(même au réglage maxi) s'agissant d'un appareil pour l’extérieur dommage. Mon pc ne le détecte pas toujours et je suis donc obligé d'enlever ma carte SD et la charger en musique. J'ai de plus eu des ennuis avec la batterie qui a gonflé. Heureusement le SAV de audiophonics a été top et me la changé. La batterie se décharge toute seule parfois (panne intermittente?) En résumé bon son , compacte, petit mais ce sont les a cotés qui pêchent
This review has been posted for XDUOO X2S Digital Audio Player DAP 24bit 192kHz DSD128
bien pour un DAP d'appoint
Ce DAP est parfait sauf sur un point : aigus assez prononcés et difficilement régalbles avec l'EQ. Fonctionne bien avec un casque Truthhear x crinacle Zero, ce casque ayant des aigus assez doux d'où un équilibre tonal correct. Donc attention au casque utilisé.
Je'utilise donc ce combo en ballades avec l'immpression de ne rien avoir en poche du fait de la taille de ce DAP.
Petit DAP au son étonnant pour son prix !
Si vous voulez du son de qualité (à mes oreilles) au meilleur prix et que vous n’êtes pas rebuté par une interface rudimentaire et quelques bizarreries (classement des fichiers et parfois des titres dans les fichiers), ce DAP devrait vous satisfaire.
Son utilisation est très intuitive, les commandes se trouve facilement à l’aveugle (DAP dans la poche) et il semble plutôt solide.
Il est léger et discret, bref en nomade il est parfait pour moi.
Un conseil : télécharger le dernier firmware : https://xduoo.net/firmware-download/
Excellent
Petit mp3 " à l'ancienne", sans bluetooth, mais solide et bien fini.
Qualité du son au top.
simple et efficace
baladeur comme on en trouve plus, pas d'écran photovidéo ni gadget online qui ne servent à rien, simple avec une bonne puissance et avec un prix abordable, ce qui n'existe plus ! donc merci. structure robuste, à voir durée de vie des touches.
xDuoo offers with its X2S a particularly compact and practical digital music player, offering however very good sound performances. Its internal...
