AUDIOPHONICS Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for Audiophonics LPSU100 Power Supplies 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can only be used with our Audiophonics LPSU100 power supplies, replacing the original cables. This cable is indeed designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity.
Reference : 17397
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 03-06-2025.
This cable is ONLY COMPATIBLE with the following power supply references: 8718/14183/9646/8817/9575/9645/13387/11501/9644
Audiophonics Power cable
Audiophonics Câble d'alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC 1m
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can only be used with our Audiophonics LPSU100 power supplies, replacing the original cables. This cable is indeed designed with a Sommercable Meridian SP215 cable made of OFC copper conductors with a section of 1.5mm², ensuring an excellent electrical conductivity. It is terminated with Viborg DC21G and GX16G connectors with gold-plated copper alloy contacts, maintaining a very good level of conductivity while ensuring a high resistance to oxidation. The cable is finally covered with a beautiful yellow and grey braided sheath from Viablue.
This cable is only compatible with Audiophonics LPSU100 power supplies.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC 1m
Product typePower cable
Length1m
Connectors1* GX16
1* Jack DC 5.5/2.1mm
Cable conductors materialOFC Copper
Cable conductors section2*1.5mm²
Cable diameterØ8mm
Connectors contacts platingGold
Cable colorGray and yellow
Connectors colorGray
Length (m)1.0
ShieldingNC
Section (mm²)1.5
ConnectorGX16
ConnectorJack DC
3 reviews
Great upgrade for LPS
Significantly better quality compared to the original cables that came with the LPS. The sound is a bit more spacious and open. The quality and design are perfect—definitely not snake oil.
This review has been posted for AUDIOPHONICS Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for Audiophonics LPSU100 Power Supplies 1m
Excellent
La différence est sensible par rapport au câble d'origine de l'alimentation linéaire 12V.
Meilleure qualité apparente et contacts parfaits.
Une meilleure définition générale et une image stéréo plus ample et étagée.
Excellent Rapport Qulité/Prix
Beau produit, bien protégé et expédié rapidement. Utilisé pour connecter l'alimentation régulée au miniPC
This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It...
