AUDIOPHONICS HA-B6120 Full Balanced Headphone Amplifier TPA6120 OPA2604
The Audiophonics HA-B6120 is a balancedheadphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of high-performance components. Thus, the amplifier stage of the device embeds a TI TPA6120 chip allowing the HA-B6120 to develop an important power in order to accompany high sensitivity earphones as well as high impedance headphones.
Reference : 14573
189,00 €tax incl.
157,50 € tax excl.
Full Balanced Headphone Amplifier OPA2604
Audiophonics HA-B6120 Amplificateur Casque Symétrique MUSES8920
The Audiophonics HA-B6120 is a balanced headphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of high-performance components. Thus, the amplifier stage of the device embeds twp TI TPA6120 chips allowing the HA-B6120 to develop an important power in order to accompany high sensitivity earphones as well as high impedance headphones. The amplifier also offers a gain selector on the front panel to match your listening device. This amplifier stage is associated with an input stage, based on double J-FET OPA2604 OPAs in buffer, offering excellent technical characteristics.
The balanced structure of the HA-B6120 allows a reduction in distortion (0.001%) and an improvement in dynamics for a precise, rich and lively reproduction. The amplifier has a balanced XLR input, a balanced XLR 3-pin headphone output and a balanced XLR 4-pin headphone output. For added versatility, the HA-B6120 also features an unbalanced input on stereo RCA and an unbalanced headphone output on 6.35mm jack. A front-panel switch allows simple selection of XLR or RCA input.
For the rest, the amplifier benefits from an optimized design to deliver a beautiful sound reproduction, in particular through the integration of quality components such as WIMA capacitors, Philips diodes, an ALPS potentiometer or Neutrik connectors. It also incorporates an effective protection system, checking the status of the left and right channels and protecting your headphones. The integrated linear regulated power supply provides a clean electrical signal to all circuits.
Product typeBalanced headphone amplifier
Amplification chipDual TI TPA6120
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo 3 poles XLR
1x Balanced stereo 4 poles XLR
1x Single-ended stereo Jack 6.35mm
Gain switchH (High)
L (Low)
SensitivityL (Low): 1.40V RCA
H (High): 0.70V RCA
L (Low): 2.80V XLR
H (High): 1.40V XLR
Output level9V (RCA)
18V (XLR)
Frequency response2Hz - 20kHz
Distortion0.001%
Accepted impedances18 - 600 Ohm (Recommended: 300 Ohm and above)
Housing materialAluminium
ColorFront panel: Black
Rest of the housing: Silver
Dimensions (without connectors)25.2 x 16.1 x 6.2mm
Weight1.94kg
Power cableNot inclued
InputXLR
OutputJack 6.35mm
ColorSilver
ClassN/A
13 reviews
Très bon
Après une longue période de rodage, la justesse, la spontanéité de cet appareil impressionnent. La scène est bien plus large qu’avec les autres amplis casques essayés ou conservés (même bien plus chers). Il n’y a pas de duretés, les placements sont aisés à repérer, les timbres sont expressifs et posés. Cela aide beaucoup pour la composition musicale. Il aide aussi à bien choisir l’ampli opérationnel du Dac, quand c’est possible. Cet ampli casque a été livré avec des OPA 2604 (après réassortiment) plutôt que les Muses 8920 annoncés : mieux ou moins bien, je ne sais pas, en tous cas c’est très beau.
Je continuerai à demander conseil à l’équipe d'Audiophonics pour d’éventuels compléments ; d’autres amplis opérationnels ou d’autres câbles.
Le Dac et l’ampli sont reliés avec un câble symétrique Canard, TRS 6,35 M vers XLR M. La sortie est reliée au casque pour l’instant avec un câble asymétrique Syrnarn.
Je tiens à dire que le produit ne me gène pas sur le plan de la radiosensibilité : ce qui est une aubaine. Merci !
This review has been posted for AUDIOPHONICS HA-B6120 Full Balanced Headphone Amplifier TPA6120 OPA2604
Strong.
This amp has a lot of clean power. I swapped muses opamp for Burson V6 vivid or classic...depends on my mood,it shows the differences quite well, in this config it draws nice soundstage around my head. Clarity, separation and sense of power is briliant for the price. Big recommendation.
ampli casque
excellent appareil; très belle sonorité; on peut aussi changer les OP AMP selon ses goûts; très bien !
ampli casque
Super son . Utilisé avec connexion symétrique casque Audio technica
ampli casque symétrique
très bon ampli symétrique (surtout).Je l'utilise sur un dac smsl : nickel ! Son précis et ample sur audio technica ATH MSR7b.Merci pour les renseignements sur service technique (David Aubert).
The Audiophonics HA-B6120 is a balancedheadphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of...
