AUNE S17 PRO Headphone Amplifier Preamplifier Black
With its S17 Pro, Aune unveils a powerful headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features discrete components and balanced outputs. Its Class A amplification stage features a pair of JFET transistors for the headphone outputs, plus two AOPs per output for a total of 16 AOPs. Powerful, the S17 Pro is capable of driving any type of headphone on the market, from 32Ω to 600Ω impedance.
By buying this product you get 72 loyalty points
Reference : 18487
729,00 €tax incl.
607,50 € tax excl.
Last items in stock !
Shipping date: 27-05-2025.
AUNE S17 PRO
Discrete Class A Balanced Headphone Amplifier / Preamplifier 7500mW @32Ω Black
AUNE S17 PRO Discrete Class A Balanced Headphone Amplifier / Preamplifier 7500mW @32Ω Black<span id=
With its S17 Pro, Aune unveils a powerful headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features discrete components and balanced outputs. Its Class A amplification stage features a pair of JFET transistors for the headphone outputs, plus two AOPs per output for a total of 16 AOPs. It also features an R2R volume control and an attractive color display on the front panel. Inputs include stereo RCA and balanced stereo XLR. Powerful, the S17 Pro is capable of driving any type of headphone on the market, from 32Ω to 600Ω impedance.
A powerful amplifier stage
The Aune S17 Pro's amplification stage is made up of TWIN JFETs, ideal for headphone amplification. In addition, each output channel incorporates 2 pairs of transistors, giving a total of 16 transistors. This Class A headphone amplifier also features two levels of current adjustment: 50mA and 100mA per JFET. Overall, the sound of the Aune S17 Pro is warm and detailed, with performance reaching a very low level of distortion.
R2R volume control
A R2R JRC volume control chip is integrated into the Aune 17 Pro to achieve a high level of precision and a wide soundstage.
Two gain levels to drive all types of headphones
The S17 Pro can drive headphones with impedances ranging from 32 to 600 ohms. Output power can reach up to 7.5W to drive the most demanding headphones.
Efficient heat dissipation and clean power supply
A three-dimensional structure consisting of internal heat sinks, an imposing plate and the chassis forms a highly efficient complete cooling system guaranteeing the stability of the Class A amplifier stage. A 50W toroidal transformer coupled to 19200uF array capacitors feeds the digital and analog sections independently to limit any interference on the analog section. These features enable the S17 Pro to be powerful while delivering a rich, clear sound.
Color display
A handsome display on the front of the Aune S17 Pro provides information on current, temperature, output type and volume level.
Overview of the Aune S17 Pro headphone amplifier
1XLR 4-pin balanced headphone output
26.35mm headphone output
3Balanced 4.4mm headphone output
4IR reception
5Display
6Power LED indication
7Multifunction button
8RCA stereo input
9XLR stereo balanced input
10RCA stereo line output
11XLR stereo balanced line output
12Power switch / IEC power socket
Preamplifier
Inputs1x Stereo RCA input
1x Balanced stereo XLR input
Outputs1x 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x XLR 4-pin balanced headphone output
1x RCA line output
1x XLR line output
INPUT/OUTPUT IMPEDANCE
RCA input impedance10KΩ
RCA output impedance200Ω
XLR input impedance22KΩ
XLR output impedance100Ω
Headphone output impedance1Ω
6.35MM Jack HEADPHONE OUTPUT
Frequency response20Hz - 80kHz (+/- 5dB)
THD+N< 0.00038% @1kHz
SNR> 115dB @600Ω
Crosstalk< -105dB @1kHz 600Ω
BALANCED XLR HEADPHONE OUTPUT
THD+N< 0.00016% @1kHz
SNR> 116dB @600Ω
Crosstalk< -110dB @1kHz 600Ω
GAIN-RELATED OUTPUT POWER
G-L 6.35mm jack headphone output (Low Gain)
738mW @ 32Ω
250mW @ 100Ω
166mW @ 150Ω
100mW @ 250Ω
83mW @ 300Ω
53mW @ 470Ω
41mW @ 600Ω
G-L Balanced headphone output (Low Gain)
2773mW @ 32Ω
968mW @ 100Ω
645mW @ 150Ω
388mW @ 250Ω
333mW @ 300Ω
212mW @ 470Ω
166mW @ 600Ω
G-H 6.35mm jack headphone output (High Gain)
2020mW @ 32Ω
675mW @ 100Ω
453mW @ 150Ω
273mW @ 250Ω
228mW @ 300Ω
145mW @ 470Ω
114mW @ 600Ω
G-H Balanced headphone output (High Gain)
7507mW @ 32Ω
2643mW @ 100Ω
1793mW @ 150Ω
1089mW @ 250Ω
908mW @ 300Ω
580mW @ 470Ω
453mW @ 600Ω
Dimensions211 x 288 x 63mm
Package1x Aune S17 Pro headphone amplifier/preamplifier Black
1x Power cable
1x Remote control (CR1220 battery not included)
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassClass A / AB
Remote ControlYes
Méconnu ...
Aucun avis sur le S17 Pro d'Aune ?. Je suis étonné ! Après 1 semaine d'utilisation, je ne peux que me réjouir de l'avoir choisi. J'écoute beaucoup au casque, j'ai donc acheté et essayé pas mal de combinaisons d'appareils, ampli-casques ou amplis intégrés, Topping, Fiio, Smsl, Rega, Marantz, Pioneer, AD 18 qui fonctionnaient assez bien avec mon Hifiman et mon Sennheiser. Pourtant l'Aune m'a fait franchir un gap et je suis encore sous l'effet "waou" après une vingtaine d'heures.
Le S17 est en classe A, il lui faut être à bonne température avant de totalement s'exprimer (30 mn), la température est d'ailleurs indiquée sur l'écran. On peut choisir le courant de repos et le gain.
L'Aune a de la matière, de la densité tout en étant transparent et détaillé. Je peux suivre les lignes de basse comme jamais auparavant, les voix sont très présentes et suaves, les aigus sont présents, sans agressivité ou sans sibilance. Mais, la qualité à laquelle je suis le plus sensible (et mon Hifiman aussi), est la séparation des instruments, l'espace que prend la musique, l'image, certainement fausse en réalité, mais tellement plaisante pour ceux qui aiment écouter au casque.
Trop de qualités pour être vrai diront certains ... oui, le temps me fera sans doute modifier une partie de mon appréciation. Mais pour l'instant, je profite de ma "lune de miel avec cet appareil" et ce, j'espère, pour un long moment.
Nb 1 : pour éviter de trop monter en température, mieux vaut surélever l'appareil. Je l'ai fait en le positionnant sur 4 petites équerres de bricolage placées en dessous, en position horizontale.
Nb 2: la pile de télécommande est fournie, contrairement à la description. (j'ai fait 15 kms pour rien!).
Nb3 : Commande passée un mercredi matin et reçue le vendredi matin à 700 kms d'Audiophonics ... chapeau !
This review has been posted for AUNE S17 PRO Discrete Class A Balanced Headphone Amplifier / Preamplifier 7500mW @32Ω Black
With its S17 Pro, Aune unveils a powerful headphone amplifier that can also be used as...
