HIFIMAN SERENADE WIFI R2R DAC
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and streamer, thanks to an RJ45 LAN port and WiFi functionality. The device was developed by HIFIMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification circuitry. The HIFIMAN Serenade's wide range of connectors and functions make it a DAC that will fit into almost any Hi-Fi installation.
By buying this product you get 113 loyalty points
Reference : 20504
1 139,00 €tax incl.
949,17 € tax excl.
Shipping date: 12-09-2025.
HIFIMAN SERENADE WiFiDAC R2R Preamplifier Class A Headphone Amplifier LAN RJ45 32bit DSD512
DAC HIFIMAN SERENADE picture
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as preamplifier, headphone amplifier and streamer, thanks to an RJ45 LAN port and WiFi functionality. The device was developed by HIFIMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification circuitry. The HIFIMAN Serenade's wide range of connectors and functions make it a DAC that will fit into almost any Hi-Fi installation.
HIFIMAN SERENADE DAC circuit diagram
HIFIMAN SERENADE WiFi: WiFi functionality
A new version of the HIFIMAN Serenade, this version integrates WiFi functionality for enhanced wireless connectivity. The HIFIMAN offers full network player functionality for optimum versatility. A true gateway, it supports numerous applications for easy access to all your music libraries.
HiFiman Serenade WiFi functionality
HIFIMAN Serenade WiFi: R2R Hymalaya Pro DAC
With support from a new FGPA algorithm, Hymalaya R2R DAC technology achieves a THD of 0.0012% (-6db). Coupled with the XMOS XU316 USB interface, the Serenade DAC is able to support high-resolution PCM 32bit 384kHz and DSD256 streams via its USB input, 24bit 192kHz and DSD DoP64 streams via its coaxial SPDIF and Toslink optical inputs, as well as 32bit 768kHz and DSD512 streams via network.
Photo of DAC Hymalaya architecture
Photo of the HIFIMAN SERENADE headphone amplifier circuit
HIFIMAN Serenade WiFi: Class A headphone amplifier circuitry
The HIFIMAN Serenade's headphone amplifier circuit is based on a Class A circuit architecture for a powerful, round and warm sound. It features 3 headphone outputs on the front panel, a balanced XLR 4-pin headphone output, a balanced 4.4mm jack headphone output and a 6.35mm jack headphone output.
HIFIMAN Serenade WiFi: RJ45 LAN port
The Serenade's RJ45 port enables it to connect to a network, so you can enjoy a NAS gateway on your local network, or stream music directly to your favorite streaming applications via your phone or tablet.
HIFIMAN SERENADE network functionality
Photo of HIFIMAN SERENADE toroidal transformer
HIFIMAN Serenade WiFi: A 50W toroidal transformer
For its power supply, the HIFIMAN Serenade benefits from a 50W toroidal transformer and a high-speed, low-noise voltage regulator circuit that enables it to operate with a clean current.
Overview of HIFIMAN Serenade WiFi connectors
HIFIMAN SERENADE connectors
1XLR 4-pin balanced headphone output
2Single-ended 6.35mm jack headphone output
3Balanced 4.4mm jack headphone output
4Input selector
5Settings
6Output selector
7Volume control
8Matrix display
9Balanced XLR stereo analog output
10Single-ended RCA stereo analog output
11Single-ended RCA stereo analog input
12Coaxial input
13Optical Toslink input
14USB-B input
15WiFi Antenna
16RJ45 LAN port
17Update port
18Power input
HIFIMAN Serenade review by ON-MAG
"The Hifiman Serenade is not only a very complete device, acting as a DAC, headphones amp, streamer and stereo preamp in one, it also shines in terms of build quality and, above all, sound quality. Mastered from start to finish, it manages to combine excellent technical qualities with high output power. A fine demonstration of the brand."
Product typeDAC R2R
Preamplifier
Headphone amplifier
Streamer
DAC technologyHymalaya Pro
Inputs1x USB-B
1x Coaxial
1x Toslink optical
1x RCA stereo
WiFi
Outputs1x Balanced XLR stereo
1x Single-ended RCA stereo
1x Balanced XLR 4-pin headphone output
1x Single-ended 6.35mm jack headphone output
1x Balanced 4.4mm jack headphone output
Other connectorsRJ45 port
Update port
Compatible protocolsUPnP/DLNA, AirPlay, Roon Ready
Supported sampling ratesUSB: PCM up to 32bit 384kHz, DSD up to DSD256
Coaxial / Optical: PCM up to 24bit 192kHz, DSD DoP64
Network: PCM up to 32bit 768kHz, DSD up to DSD512
Frequency response20Hz-20kHz (+/-0.1dB @1kHz)
THD+N0.0015% (-3dBFS @ 1kHz)
SNR- 110dB (0dBFS @ 1kHz)
Channel separation- 120dB (0dBFS @ 1kHz)
DAC output levelXLR : 4.5V RCA : 2.5V
Headphone output power (@ THD+N < 0.07% @ 1kHz)Balanced XLR and 4.4mm jack outputs: 4000mW @ 32Ω / 760mW @ 300Ω
Single-ended 6.35mm jack headphone output: 2800mW @ 32Ω / 510mW @ 300Ω
Dimensions300 x 255 x 50mm
Net weight3.9Kg
Package1x HIFIMAN Serenade WiFi
1x Power cable
InputWiFi
InputRJ45
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate768kHz
NetworkingYes
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsUpnP
HIFIMAN SERENADE WIFI DAC R2R Preamplifier Headphone Amplifier Class A WiFi LAN RJ45 32bit 768kHz DSD512
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and streamer, thanks to an RJ45...
