By buying this product you get 224 loyalty points
The iFi Pro iCAN SIGNATURE tube preamplifier and headphone amplifier is the quintessence of the know-how of the brand itself supported by the prestigious company AMR. Based on a hybrid circuit of transistors and tubes, the iFi Pro iCAN SIGNATURE embeds the best of these two technologies and not a caricatural compromise.
We can therefore choose the sound as desired by inserting the tube or only transistor sound into the circuit.
The stereo input is via a very low distortion fast JFET transistor stage accompanied by a bipolar stage assisted by a class A Mosfet stage. The tube stage is amplified by two 5670 GEs as close as possible to the ALPS "Black Beauty" potentiometer. "6-track in true balanced mode.
Thus the iFi pro iCAN SIGNATURE stereo preamplifier is fully symmetrical from input to output on a 4-layer printed circuit.
The circuit diagram fully optimized in current-coupled mode has no capacitors in its path that could degrade the original signal.
Only handpicked components are in this preamplifier: Vishay MELF capacitors, TDK COG for the audio part, Elna Silmic II and Panasonic Foil for the power supply part.
This symmetrical stereo preamplifier is a studio quality headphone amplifier capable of delivering very high power (14000mW) to "drive" any of the most demanding symmetrical audiophile models, in particular models from Sennheiser, Audeze and Hifiman.
Like any high-end headphone amplifier, the gain is fully adjustable in three positions: 0dB, 9dB, 18dB.
Gain | 0dB, 9dB, 18dB to select with switch |
Tube | 2 tubes 5760 GE |
Frequency response | 0.5Hz to 500kHz(-3dB) |
Total harmonic distorsion | Transistor stage : ≤0.0015% ≤0.005%, Tube+: ≤0.012% ≤0.2% |
SNR | Balanced : >147dB(A) Unbalanced : > 137dB(A) |
Output power | Balanced >14,000mW @ 16Ω Unbalanced >4,800mW @ 16Ω |
Voltage level for 600 Ω | Balanced : >23V Unbalanced : >11.5V |
Average power consumption | ≤ 22W, 50W max |
Inputs | 3x RCA stereo unbalanced gold plated 1x XLR balanced |
Outputs | 1x XLR variable balanced 1x RCA variable unbalanced gold plated 2x Jack 6.35mm switchable to a balanced output 1x headphone output 4 pins balanced 1x Jack 3.5mm TRS unbalanced 1x Jack 3.5mm TRS balanced |
Dimensions | 213x 193 x 63 mm |
Net Weight | 1.93kg |
Total Weight | 6kg |
Input | RCA |
Input | XLR |
Output | Jack 3.5mm |
Output | Jack 6.35mm |
Output | RCA |
Output | XLR |
Color | Silver |
Class | Tube amp |
Remote Control | Yes |
