SMSL SAP-12 Headphone amplifier Class A/B 210mW 32 Ohm Silver
Class A / B headphone amplifier with discrete component output stage. Delivers a well-defined sound with a very low distortion rate (0.0003%) and an excellent signal-to-noise ratio of 110dB.
Reference : 12817
125,00 €tax incl.
104,17 € tax excl.
SAP-12 SMSL Headphone Amplifier class A / B 210mW / 32ῼ
With the SAP-12 SMSL endeavored to produce a powerful and versatile headphone amplifier at very affordable prices. Integrated into an aluminum body insulation electromagnetic interference, the class A / B amplifier has a good reactivity and a warm that will mobilize all the qualities of headphones.
output stage with discrete components
headphone SMSL SAP-12
helmet class A / B amplifier with an output stage with discrete components. Delivers a definite advantage of a very low rate distorstion (0.0003%) and an excellent ratio S / N 110dB.
volume button and ALPS potentiometer
Volume Knob
The SAP-12 SMSL is equipped with a volume knob operating with a high-precision potentiometer ALPS. The setting of the output level offers fine adjustment possibilities to find a comfortable listening volume, balanced and conducive to bring out the nuances of sound.
RCA output
RCA prémampli
A second pair of RCA bypasses the headphone output stage and to use the SMSL SAP-12 as a preamplifier with very low distortion with a control accessible and specific volume.
The RCA connectors are gold plated for optimum conductivity and excellent resistance to oxidation and other damage.
Qobuzissime for this awesome SMSL SAP-12
Qobuz has tested the SAP-12 SMSL at length for you, from a general presentation to a concrete listening, including an analysis of the components. The SMSL headphone amplifier is awarded a very beautiful Qobuzissime for its breathtaking sound quality !
Qobuzissime SMSL SAP-12
OutputsRCA
6.35mm
SNR110 dB
THD + NHeadphones: 0.0009%
CAR: 0.0003%
Volume ControlYes (ALPS potentiometer)
Input VoltageDC5V
Power consumption1.5W
Headphone Output Power32 ohms: 210mW
64 ohms: 160mW
150 ohms: 93mW
300 ohm: 52mW
600 ohms: 28mW
HousingAluminum
Parts suppliedDC5V Power Cable
AC adapter
Dimensions120 x 92 x 22 mm
OutputJack 6.35mm
ColorSilver
2 reviews
I use it in combination with SMSL SANSKRIT 10Th MKII DAC, and it sounds terrific! I absolutely recommend it!
This review has been posted for SMSL SAP-12 Headphone amplifier Class A/B 210mW 32 Ohm Silver
Amplificateur méritant le quobuzissime
Excellent produit, acheté suite à la recommandation quobuz, très satisfait, excellent reproduction/ dynamique, puissance suffisante pour casque Hifi. Seul reproche le bouton de volume est très lisse et petit ce qui rend parfois le réglage peu précis.
Class A / B headphone amplifier with discrete component output stage. Delivers a well-defined sound with a very low distortion rate (0.0003%) and...
