By buying this product you get 99 loyalty points
With the TA-32, xDuoo unveils a balanced Class A headphone amplifier and DAC based on a ROHM BD34301, a 5U4G tube and two 12AU7 tubes. These audiophile components enable it to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA via its USB-B input, as well as headphones output power up to 3000mW into 32 ohm. In addition, a Qualcomm QCC5125 chip provides Bluetooth 5.1 support for a wide range of codecs: SBC, AAC, aptX, aptX LL, aptX HD and LDAC. Versatile, the TA-32 features numerous inputs and outputs for easy integration into any Hi-Fi system, whether as a DAC or headphones amplifier.
The xDuoo TA-32 is based on a hybrid design consisting of a 5U4G rectifier tube, two 12AU7 amplifier tubes and Class A transistors. The combination of these components delivers a warm, smooth sound, while enabling output power of up to 300mW under 32 ohm. The TA-32 is therefore able to drive headphones and IEMs with impedances from 32 to 600 ohm via its various headphone outputs: balanced 4.4mm jack, balanced 4-pin XLR and single-ended 6.35mm jack.
The TA-32's digital-to-analog conversion is based on a ROHM BD34301 DAC chip. It supports sampling rates up to PCM 32bit DSD512 and MQA via its USB-B input, and PCM 24bit 192kHz via its Toslink optical, coaxial and AES/EBU inputs. What's more, this DAC chip comes in the form of a card that can be easily replaced by another DAC produced by the brand, should you wish to experiment with different types of sound rendering.
The xDuoo TA-32 features Bluetooth 5.1 functionality thanks to a Qualcomm QCC5125 chip supporting high-definition codecs such as aptX, aptX LL, aptX HD and LDAC for the most reliable and stable wireless transmission.
1 | 3.12” OLED display |
2 | Control buttons |
3 | Volume/source button |
4 | 5UG4 tube |
5 | 2x 12AU7 tubes |
6 | Single-ended Jack 6.35mm headphones output |
7 | Balanced Jack 4.4mm headphones output |
8 | Balanced XLR 4-pin headphones output |
9 | Balanced XLR line output |
10 | AUX RCA DAC / TUBE output |
11 | AUX RCA input |
12 | Balanced XLR input |
13 | AES/EBU input |
14 | Coaxial input |
15 | Toslink optical input |
16 | USB-B input |
17 | Bluetooth antenna |
18 | 110/240V mains voltage switch |
19 | IEC power supply / power switch |
Product type | DAC Headphone amplifier |
DAC chip | ROHM BD34301 |
Amplification components | 1x 5UG4 Tube 2x 12AU7 tubes 4x Class A transistors |
Bluetooth chip | QCC5125 |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x AES/EBU 1x AUX RCA input 1x Balanced XLR input Bluetooth |
Outputs | 1x Balanced Jack 4.4mm headphones output 1x Balanced XLR 4-pin headphones output 1x Single-ended Jack 6.35mm headphones output 1x RCA DAC output 1x RCA Tube output 1x Balanced XLR output |
Supported sample rates | USB: PCM up to 32bit 768kHz, native DSD up to DSD512, MQA Toslink optical, coaxial, AES/EBU: PCM up to 24bit 192kHz, DSD DoP64 |
Supported bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
OS compatibility | Linux, Windows, MAC OS, IOS, Android |
Compatible headphone impedance | 16-600 ohm |
Display | OLED 3.12" |
Single-ended Jack 6.35mm headphones output specifications | |
Output power | 2300mW @ 32 ohm |
Frequency response | 20Hz-60kHz (+/-0.5dB) |
THD+N | ≤ 0.01% |
SNR | 116dB |
Crosstalk | 75dB |
Balanced Jack 4.4mm / XLR 4-pin headphones output specifications | |
Output power | 3000mW @ 32 ohm |
THD+N | ≤ 0.03% |
SNR | 118dB |
Crosstalk | ≥ 104dB |
Single-ended AUX OUT RCA specifications | |
Output level | 2.0Vrms |
Frequency response | 20Hz-20kHz (+/-0.5dB) |
THD+N | 0.0007% |
SNR | 117dB |
Crosstalk | ≥ 108dB |
Balanced XLR output specifications | |
Output level | 4.0Vrms |
THD+N | 0.0006% |
SNR | 125dB |
Crosstalk | ≥ 113dB |
Power supply | AC 100-120/220-240V |
Dimensions | 31 x 24 x 17cm |
Weight | 5.4kg |
Color | Grey |
Package | 1x xDuoo TA-32 1x 5U4G Tube 2x 12AU7 tubes 1x Power supply cable |
Input | RCA |
Input | SPDIF |
Input | AES/EBU |
Input | USB |
Input | XLR |
Input | Optical |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
DAC / ADC Chip | ROHM BD34301EKV |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Max sampling rate | MQA |
Color | Gray |
Class | Class A / AB |
Class | Tube amp |
Networking | No |
Remote Control | No |
