MINIDSP POCKETADC ADC Converter
The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks to a DIP switch on one of the front panels, it can convert at several sampling rates up to PCM 24bit 192kHz.
Reference : 20654
74,90 €tax incl.
62,42 € tax excl.
Shipping date: 04-06-2025.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz
Photo of MINIDSP POCKETADC
The miniDSP PocketADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs : a Toslink optical output and a coaxial output. Thanks to a DIP switch on one of the front panels, it can convert at several sampling rates up to PCM 24bit 192kHz. Conversion is carried out in such a way as to take advantage of optimal signal digitization for low-noise rendering. Finally, the miniDSP PocketADC is supplied with 12V via DC jack, and also has a secondary power supply output for powering a third-party device.
MINIDSP POCKETADC highlights
Product typeADC converter
ADC ChipES9821Q
Input1x RCA
Outputs1x Optical Toslink
1x Coaxial
Compatible sample rates24bit 48kHz / 96kHz / 192kHz (selection via DIP switch)
Frequency response20Hz-20kHz (±0.1dB)
Max. input level2Vrms
Input impedance100KΩ
SNR (Signal to Noise Ratio)118dB
THD+N @1kHz-114dB (0.0002%)
Crosstalk-130dB
Power supply12V DC via DC jack (power supply included)
Power consumption2W (idle)
Dimensions13 x 40 x 62mm
Package1x miniDSP PcketADC
1x Power adapter 12V 1.6A
2x DC jack connection cable
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipES9821Q
Max sampling rate192kHz
ColorSilver
Excellent box
I have a soundbar that lacks of any analogue inputs. Using this device I can connect my old AM/FM tuner to it. The build and sound quality is excellent
This review has been posted for MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz
The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and...
