WONDOM AA-AS41115 ADC Analog-to-Digital Converter 24bit / 48kHz
This 24bit analog-to-digital converter offers a dynamic range of 95dB with a harmonic distortion of -91dB.
4.4 / 5
Reference : 14430
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 27-05-2025.
ADC wondom
This 24bit / 48kHz analog to digital converter offers a dynamic range of 95 dB with a harmonic distortion of -91dB.
Very easy to use, it has a stereo RCA input and two digital outputs (Coaxial & Toslink).
When the two outputs are connected simultaneously, the digital stream is automatically sent to the coaxial connector.
The device needs 5V / 200mA through a micro-USB connector.
TypeADC (Analog to digital converter)
ADC chipCS5343
Dimensions99.06mm x 99.06mm
Weight380g
InputsStereo RCA x1
OutputsToslink x1
Coaxial x1
Power supply via micro USB5V DC / 0.2A minimum
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rate48kHz
9 reviews
Good
There is light hiss, but only noticeable few inches from tweeter..
Tried with nokia, iphone and raspberry pi charger, same kind of noise..
I have no complaints about the sound..
This review has been posted for WONDOM AA-AS41115 ADC Analog-to-Digital Converter 24bit / 48kHz
Easy purchase, works with no hassle
Does what it says, just plug it in and it works. I have it connected to an optical cable to drive a set of Edifier S350DB speakers at the opposite side of the room, which support a 48khz signal. No problems.
Works fine!
Does it’s job. Doesn’t include a power adapter, but hooked it up to an old iPhone brick (1A) and an old Micro USB cable.
Vraiment au top !!!
Pour remplacer un équivalent venant d'un vendeur anonyme GAFA ...
Pour sonoriser via fibre optique un piano numérique Dexibell
La qualité de son est nettement supérieure !!!
Déçu
La qualité de fabrication a l'air correcte, pourtant il y'a un bruit de fond / sifflement qui ne passe pas inaperçu dès lors que l'on monte le volume et ce quelle que soit la source d'alimentation utilisée.
