Version 2014 of the NFB-2.32, the Dac NFB-2 is equipped with the Saber component WM8741.
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The 100% discreet design of this converter is backed by a high power (Class A) power supply.
INGREDIENTS | ||
Interface / Converter | WM8805 | |
STARTERS | ||
USB | Usb x1 | |
Coaxial | RCA x1 BNC x1 | |
Toslink | Optical x 1 | |
EXITS | ||
Analog | RCA x 2 | |
ACSS | ACSS x 2 |
Features:/ Strong>
Signal / noise ratio |
Output Level |
Supported sampling rates |
Input sensitivity | 0.5 Vp-p (75 ohms, coaxial) |
Output impedance | 10 ohm |
Frequency Response |
Consumption | 15W |
Dimensions Weight | 240 X 320 X 80mm 5KG |
Accessories | AC power cord X1 USB cable X1 |
Input | USB |
Input | Optical |
Input | SPDIF |
Input | BNC |
Output | RCA |
Output | ACSS |
DAC / ADC Chip | PCM1794 |
DAC / ADC Chip | WM8741 |
DAC / ADC Chip | PCM1704UK |
DAC / ADC Chip | Tenor 7022 |
DAC / ADC Chip | AD1955 |
DAC / ADC Chip | CS4398 |
DAC / ADC Chip | WM8740 |
DAC / ADC Chip | Sabre 32 |
DAC / ADC Chip | AK4137EQ |
DAC / ADC Chip | CS5343 |
DAC / ADC Chip | ES9018 |
DAC / ADC Chip | ES9023 |
DAC / ADC Chip | ES9016 |
DAC / ADC Chip | CM6533 |
DAC / ADC Chip | ES9028PRO |
DAC / ADC Chip | AK4399 |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 192kHz |
Color | Black |
