XDUOO ES9039SPRO DAC Module Card ES9039SPro
The xDuoo ES9039SPro DAC module card allows you to quickly and easily change the sound output on various xDuoo devices, such as the XD05 PRO portable DAC headphone amplifier or the xDuoo TA-32 headphone amplifier. This DAC module card is specially designed to deliver a wide soundstage with pronounced detail, making this module ideal for listening to classical music.
Reference : 20919
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 07-04-2026.
xDuoo ES9039SPRO DAC Module Card ES9039SPro for XD05 Pro / TA-32
XDUOO ES9039SPRO : Front view
Product typeDAC module board
CompatibilityxDuoo XD05 Pro
xDuoo TA-32
Output specifications with XD05 PRO
Output powerSingle-ended output: 2000mW (32Ω, THD+N < 1%) / 240mW (300Ω, THD+N < 1%)
Balanced output: 2000mW (32Ω, THD+N < 1%) / 930mW (300Ω, THD+N < 1%)
Output impedanceSingle-ended output: ≤ 0.2Ω
Balanced output: ≤ 0.4Ω
Peak voltageSingle-ended output: 23.8Vp-p (Mode Turbo)
Balanced output: 47.2Vp-p (Mode Turbo)
Frequency responseSingle-ended output: 20Hz-20kHz (±0.5db)
Balanced output: 20Hz-60kHz (±0.5db)
CrosstalkSingle-ended output: ≥ 72dB
Balanced output: ≥ 105dB
AUX output: ≥ 96dB
Balanced line output: ≥ 100dB
Total harmonic distortion more noise (THD+N)Single-ended output: 0.0007%
Balanced output: 0.0007%
AUX output: 0.0008%
Balanced line output: 0.0005%
Rapport signal sur bruit (SNR)Single-ended output: ≥ 120dB
Balanced output: ≥ 120dB
AUX output: ≥ 120dB
Balanced line output: ≥ 128dB
Output levelAUX output: 2.0V
Balanced line output  4.0V
Output specifications with TA-32
Output powerSingle-ended output: 2300mW
Balanced output: 3000mW
Frequency responseSingle-ended output: 20Hz-60kHz (±0.5db)
AUX output: 20Hz-20kHz (±0.5db)
Balanced line output: 20Hz-20kHz (±0.5db)
CrosstalkSingle-ended output: ≥ 75dB
Balanced output: ≥ 104dB
AUX output: ≥ 108dB
Balanced line output: ≥ 113dB
Total harmonic distortion more noise (THD+N)Single-ended output: 0.01%
Balanced output: 0.03%
AUX output: 0.0007%
Balanced line output: 0.0006%
Rapport signal sur bruit (SNR)Single-ended output: ≥ 116dB
Balanced output: ≥ 118dB
AUX output: ≥ 117dB
Balanced line output: ≥ 125dB
Balanced line output: 4.1V
Dimensions18.5 x 9.5 x 3.3cm
Weight0.78kg
Package1x xDuoo ES9039SPRO
InputNC
OutputNC
DAC / ADC ChipES9039PRO
Max sampling rate768kHz
Max sampling rateDSD512
ColorGray
XDUOO ES9039SPRO DAC Module Card ES9039SPro for XD05 Pro / TA-32
The xDuoo ES9039SPro DAC module card allows you to quickly and easily change the sound output on various xDuoo devices, such as the XD05 PRO...
