The xDduoo Link10 is a compact yet powerful portable DAC. Designed around two Cirrus Logic CS43131 DAC chips, it is capable of converting signals up to 32bit 384kHz PCM and DSD256 while delivering 2x300mW of output power at 32Ω.
For its digital-to-analogue conversion stage, the Link10 relies on two Cirrus Logic CS43131 chips to support signals up to 32-bit 384kHz PCM and DSD256. These high-quality chips ensure impressive conversion accuracy, with a signal-to-noise ratio of nearly 130dB and a harmonic distortion rate of only -115dB.
With an output power of 2x300mW at 32Ω, the Link 10 is perfectly capable of driving most earphones and low-impedance headphones, making it compatible with a wide range of devices so you can always take it with you.
To manage its volume, the Link 10 uses precise 60-step digital control, ensuring that the sound rendering is not affected by the impedance and sensitivity specific to each pair of headphones or earphones.
The Link10 is equipped with two output jacks: one 3.5mm and one 4.4mm, ensuring full compatibility with all existing headphone and earphone models while offering a choice between single-ended and balanced output. Furthermore, in the spirit of extended compatibility, the Link 10 also features UAC 1.0 mode for use with devices such as game consoles.
Despite its minimalist design with just a few buttons, the Link10 offers a wide range of functions thanks to its shortcut keys. For example, to change the DAC filter, simply press the volume + and – buttons simultaneously for one second.
A single click on the red button pauses your music, a double click skips to the next track and a triple click returns to the previous track. Furthermore, pressing and holding the button for 3 seconds switches to GAIN mode. Finally, holding down the button while connecting a source to the USB-C input activates UAC 1.0 mode.
| Specifications | |
| Product type | Portable DAC |
| Input | 1x USB-C |
| Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
| Jack 3.5mm output power | 250mW @ 32Ω 140mW @ 75Ω 70mW @ 150Ω 45mw @ 300Ω |
| Jack 4.4mm output power | 300mW @ 32Ω 350mW @ 75Ω 270mW @ 150Ω 170mw @ 300Ω |
| DAC Chips | 2x CS43131 |
| Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| Total harmonic distorsion more noise (THD+N) | Single-ended output: 106dB @ 1kHz Balanced output: 108dB @ 1kHz |
| Signal-to-noise ratio (SNR) | Single-ended output: ≥ 126dB Balanced output: ≥ 130dB |
| Crosstalk | Single-ended output: ≥ 75dB Balanced output: ≥ 112dB |
| Frequency response | 20Hz - 20kHz (±0.5dB) |
| General | |
| Dimensions | 60 x 23 x 13mm |
| Weight | 25g |
| Color | Black |
| Package | 1x xDuoo Link 10 1x USB-C cable 1x USB-A to USB-C adapter |
| Input | USB |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| DAC / ADC Chip | CS43131 |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
