NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Pure Silver Quad shielding Ø7.6mm
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding.
Reference : 15662
65,90 €tax incl.
54,92 € tax excl.
Shipping date: 18-12-2025.
Câble vendu au mètre
Neotech NEVD-2001
Coaxial Cable 75 Ohm Silver Shielded
Neotech NEVD-2001 Câble Coaxial 75Ω Argent Blindé
Neotech's NEVD cable is carefully designed especially for the transmission of digital audio signals. The main characteristic of the digital audio signal is the transmission of very high frequencies. Therefore, the brand has particularly worked on minimizing the signal loss.
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
Product typeCoaxial cable
Impedance75Ω
ConductorPure Silver
Quad ShieldingPolyethylene foam
Cu-Mylar foil
Microporous PTFE
Braided SP-OFC
Cross-section0.32mm² (22AWG)
Conductor diameter0.64mm
Overall diameterØ8mm
QuantitySold by the meter
Diameter (mm)7.6
Number of conductors1
Insulation materialPTFE
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Conductors material (Cable)Silver
Ground / ShieldingYes
4 reviews
Remarquable câble numérique
En connexion numérique streamer ou CD vers Dac le résultat est exceptionnel.
Ayant testé de nombreux câbles numériques y compris des montages perso en argent pur, c'est ce câble NEOTECH qui procure actuellement le meilleur résultat.
ATTENTION a bien l'équiper de connecteur en 75 Ohms (ici un RCA Canare et un BNC).
Mon câble est ici en 1m, mais des écoutes comparatives faites entre 1 m et 1.50m confirment qu'une longueur de 1m50 serait conseillée.
Sa disponibilité ici au m implique hélas d'en commander 3m à diviser par deux. (Avoir un ami audiophile n'est pas inutile dans ce cas...)
This review has been posted for NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Pure Silver Quad shielding Ø7.6mm
Magnifique...!
Installé sur rca canare 75ohms.
Avec dernier blindage raccordé que d un côté.
Ce câble sonne très analogique et naturel.
On ne se pose plus de question.
Le câble
Bien respecter le dernier blindage que d un côté.
Musicalement ce câble est simplement "parfait"
Naturel et analogique.
Bravo
Very good quality
This cable did not disappoint, I made a coaxial cable to use with my AN dac 4.1. I used the WBT 0110 ag 75ohm connectors, and WBT solder with silver in it for the purest connection possible.
It sounds incredible, and you will never need to upgrade to anything else.
Highly recommended :)
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum...
