It's incredible how much the DI25HE can improve the already excellent AGD R27HE.
A highly recommended product!
Audiphonics is, as usual, a top website for purchasing high-quality products!
Immediate shipping!
Thanks and see you soon.
By buying this product you get 119 loyalty points
The Audio-GD DI-25HE digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is designed to offer a plethora of options with regard to the strategies for using the clocks: interfacing from the internal clocks, using an external clock (slave mode) or offsetting the internal clock to a third-party device (master mode). This type of circuit allows integration into highly advanced audio systems.
An Altera FGPA logic circuit is responsible for generating the output signal. This high-frequency chip is isolated from the USB interface to avoid any parasitic noise, both in terms of signal conversion and clock signal accuracy.
Audio-GD's HE series features Regenerative Power Supply technology, which has undergone extensive testing and research to achieve its current incredible performance. This technology uses a thick aluminum plate to separate the power supply circuits, shields the main power supply circuit and limits the transmission of interference between the power supply and the audio circuits. The quality of this power supply system can be felt right from the first listen, with more detailed reproduction, greater dynamics, deeper bass and a wider soundstage. What's more, this technology also offers a more "analog" sound reproduction.
| 1 | Firmware update port and USB firmware reset button |
| 2 | I2S HDMI input |
| 3 | USB-B input |
| 4 | Power connector |
| 5 | 110Ω AES/EBU output |
| 6 | 75Ω coaxial output |
| 7 | BNC 75Ω 10MHz output |
| 8 | BNC output 50Ω 10MHz |
| 9 | I2S HDMI output |
| 10 | BNC input 75Ω 10MHz |
| 11 | BNC input 50Ω 10MHz |
| Specifications | |
| Product type | Digital interface |
| Inputs | 1x USB-B 1x Clock input 10MHz BNC 50Ω (0.3Vpp - 3Vpp) 1x Clock input 10Mhz BNC 75Ω (0.3Vpp - 3Vpp) 1x HDMI I2S input |
| Outputs | 1x I2S HDMI LVDS 3.3V @ 100Ω 1x Coaxial 0.5Vp-p @ 75Ω 1x AES/EBU 5Vp-p @ 110Ω 1x Clock output 10MHz BNC, > 9dBm @ 50Ω |
| USB compatibility | Windows OSX Linux ISO |
| Supported sampling rates | USB / I2S : PCM up to 32bit 384kHz, DSD up to DSD512 AES/EBU / SPDIF : PCM up to 384kHz |
| General | |
| Supply voltage | 220-240VAC 50/60Hz |
| Consumption | 17W |
| Dimensions | 360 x 240 x 85mm |
| Weight | 5kg |
| Color | Black |
| Package | 1x Audio-GD DI-25HE 1x USB cable 1x USB Interface Blaster |
| Input | I2S via HDMI |
| Input | USB |
| Input | BNC |
| Output | I2S LVDS via HDMI |
| Output | BNC |
| Output | Coaxial SPDIF |
| Output | AES/EBU |
| Max sampling rate | 384kHz |
| Color | Black |
| Interface chip | Amanero 384 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Luca C.
