LAIV AUDIO HARMONY UDDC Reclocker Galvanic Insulation Black
With the Harmony µDDC, Laiv Audio presents us a digital interface and reclocker that considerably reduces phase noise and jitter for a more natural sound rendering in an open stage. The latter is based on a Femto clock to ensure the most stable clock signal possible. Connections include USB-B, AES, I2S and coaxial, plus a galvanically isolated I2S output. Thanks to its FPGA-based signal processing, the Harmony µDDC can handle signals up to PCM 768kHz and DSD512. Finally, a 10MHz clock input is also available if you wish for an external clock to reclock your signal.
By buying this product you get 97 loyalty points
Reference : 20234
979,00 €tax incl.
815,83 € tax excl.
Laiv Audio Harmony µDDC Reclocker I2S Galvanic Insulation 768kHz DSD512 Black
Laiv Audio Harmony µDDC : 3/4 view
Laiv Audio Harmony µDDC: Signal processing with FPGA and CPLD
The Harmony µDDC uses an FPGA (Field-Programmable Gate Array) to manage the routing and processing of complex digital signals with extremely low latency. This guarantees bit-perfect data processing for high-resolution formats such as PCM 768kHz and DSD512.
In addition to the FPGA, a complex programmable logic device (CPLD) manages the synchronization of critical signals, minimizing phase noise and jitter. This division of processing tasks guarantees greater efficiency and precision for each operation.
Laiv Audio Harmony µDDC: Femto clock and FIFO buffer
The Harmony µDDC incorporates a femto clock to reduce jitter to an infinitesimal level, guaranteeing the integrity of the digital audio signal's synchronization. This is particularly important for maintaining the transparency of audio reproduction permitted by high-resolution formats.
A robust FIFO (First-In-First-Out) buffer system synchronizes incoming and outgoing signals, eliminating timing irregularities caused by the source. The result is a continuous, clocked output that retains the original sound characteristics.
Laiv Audio Harmony µDDC: Reclocking technology
µDDC Harmony's reclocking mechanism realigns signal synchronization using the femto clock, effectively “cleaning” the digital signal of jitter introduced by upstream devices. This improves signal integrity, as well as the clarity, dynamics and resolution of the soundstage. To maintain signal purity, the I²S output is galvanically isolated, preventing electrical interference and noise propagation from the source to downstream components.
Laiv Audio Harmony µDDC: Designed for high-end installation
The Harmony µDDC has been designed to integrate high-end HiFi systems, supporting audio signals up to PCM 768kHz and DSD512. Furthermore, if you wish for it, a 10MHz clock input is available, allowing you to use an external clock instead of the internal one.
Laiv Audio Harmony µDDC: I2S pinout
Laiv Audio Harmony µDDC : I2S pinout
Product typeReclocker
Galvanic isolator
Supported sampling ratesUSB-B : PCM 768kHz DSD512
I2S : PCM 768kHz DSD512
Coaxial / AES : PCM 192kHz DoP64
Inputs1x USB-B
1x I2S via HDMI
1x AES
1x Coaxial
1x BNC 10MHz clock input
Output1x I2S via HDMI
Power supply ports1x USB-C
1x Jack DC
Supply voltage5V
Dimensions168 x 98 x 50mm
Weight600g
Package1x Laiv Audio Harmony µDDC
1x Mains adapter
InputI2S via HDMI
InputClock (BNC)
InputAES/EBU
OutputI2S LVDS via HDMI
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipFPGA
Brilliant device!
After long consideration I bouth the Laiv DDC. It made an amazing improvement in the sound. I am delighted. Just for the record, I feed the DDC
This review has been posted for LAIV AUDIO HARMONY UDDC Reclocker I2S Galvanic Insulation 768kHz DSD512 Black
With the Harmony µDDC, Laiv Audio presents us a digital interface and reclocker that considerably reduces phase noise and jitter for a...
