MUSICIAN PISCES II Digital Interface
Musician offers with the Pisces II a high quality digital interface, capable of providing a clean and stable transmission of the audio signal. It offers a complete range of outputs to suit most audio systems and needs. In addition, the Pisces supports high definition audio streams for the most accurate and transparent sound reproduction possible.
By buying this product you get 62 loyalty points
Reference : 16701
629,00 €tax incl.
524,17 € tax excl.
Shipping date: 07-04-2026.
Musician PISCES ii
Digital Interface I2S USB SPDIF 24bit 768kHz DSD512
Musician Pisces II Interface Numérique I2S USB SPDIF 24bit 768kHz DSD512
Musician Pisces II: Proprietary USB interface
The USB-B input of the Pisces II is associated with a proprietary high-end USB interface based on a proprietary STM32F446 MCU. It supports high resolution audio streams, allowing the playback of PCM files up to 24bit 768kHz and DSD512.
Musician Pisces II: Data processing by FPGA
The Musician Pisces II conceals in its heart a powerful Altera Max II FPGA. This one is in charge of decoding the digital data and allows to reduce the signal path while limiting the sound coloration.
Musician Pisces II: Digital Isolation
The digital signal of the Pisces II is totally isolated using a high speed 50Mbps optical coupler. This technology allows to considerably reduce the noise level and to reach an excellent signal to noise ratio.
Musician Pisces II: TCXO clocks
The Musician Pisces II clock system uses two TCXO (Temperature Compensated Crystal Oscillator) oscillators for very low jitter. The TCXO system automatically adjusts the external capacitance coupling matrix by measuring temperature, in order to provide a more accurate and stable frequency.
Musician Pisces II: Optimized power supply
The power supply stage of the Musician Pisces II benefits from the same care given to the audio circuits, in order to provide them with a clean and stable electrical signal. It includes an O-Type transformer made of high quality single crystal copper wire.
Musician Pisces II: Full output connectivity
The Musician Pisces II offers a complete connectivity, especially for its outputs, and will adapt to most needs. The device offers USB-B as input as well as two inputs for external clocks. For the outputs, the Pisces offers AES/EBU, I2S via HDMI and RJ45 as well as Toslink optical and coaxial.
1Settings button
2OK button
3I2S LVDS Output (HDMI)
4Optical Toslink output
5Clock inputs
6I2S LVCMOS output (RJ45)
7AES/EBU output
8Coaxial output
9USB-B input
10Power supply connector
Product typeDigital interface
Inputs1x USB-B
1x 45.1548MHz clock input
1x 49.152MHz clock input
Outputs2x AES/EBU
1x I2S LVDS (HDMI)
1x I2S LVCMOS (RJ45)
1x Optical Toslink
1x Coaxial
Supported sampling ratesUSB : PCM up to 24bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD64
I2S : PCM up to 24bit 384kHz, Native DSD up to DSD512, DSD DoP up to DSD64
AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supply voltage100-240VAC, 50/60Hz
Consumption≤ 20W
Dimensions250 x 235 x 70mm
Weight3.5kg
InputAES/EBU
InputBNC
OutputI2S LVCMOS via RJ45
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rateDSD512
Max sampling rate768kHz
Interface chipNC
Les deux font la paire....
Ce DDC est le complément idéal de mon DAC Pegasus 2 de chez Musician. Nul doute qu'il a été conçu pour sublimer le Pegasus 2. Je l'ai branché en I2S avec le DAC et le DAC ressort en XLR vers mon ampli (MA 252). Je profite donc des deux points fort du Pegassus 2, l'I2S et le XLR. Sincèrement, je redécouvre ma musique avec une scène sonore plus précise, stable avec plus de relief. Les détails sont présents sans agressivité. Bref, il me semble que j'ai trouvé là le combo parfait ! Merci Audiophonics de nous faire découvrir de tels produits.
This review has been posted for MUSICIAN PISCES II Digital Interface I2S USB SPDIF 24bit 768kHz DSD512
Musician offers with the Pisces II a high quality digital interface, capable of providing a clean and stable transmission of the audio signal. It...
