SeeTitle
Silkline's SPFIDMAX MKII is an asynchronous USB / SPDIF interface featuring quality components such as an XMOS XU308 chip. This digital interface supports 32bit / 192kHz PCM via its USB-B 2.0 port. It uses digital filtering technology before retransmitting the signal to its outputs (Toslink and Coaxial) to improve the input signal and limit interference.
The SPDIFMAX MKII uses one of the best USB interfaces on the market, an XMOS XU308. The XMOS is an 8-core processor working with FGPA capable of processing a digital signal at a speed of 1000 MIPS in real time, and decoding up to 32bit / 192kHz PCM. This interface is compatible with the ASIO driver and therefore with a wide range of devices.
These high-precision clocks considerably reduce jitter and make the digital signal more stable.
A high-end power supply chip reduces electromagnetic interference (EMI/RFI) and incorporates a dual voltage regulation system to ensure a clean power supply system.
SilkLine has designed the SPDIFMAX MKII to increase the range of the coaxial output signal by a factor of 4. The effective transmission distance of the coaxial signal reaches over 10 meters.
Digital filter technology also enables the USB/SPDIF interface to smooth out pulse peaks, filter out first-order harmonics and guarantee a clean signal.
The Toslink output and the gold-plated coaxial output are completely independent and isolated, reducing the noise that can come from the source device.
Product type | USB to SPDIF Digital interface |
Input | USB-B 2.0 |
Outputs | 1x Optical Toslink 1x Coaxial SPDIF |
USB Interface | XOMOS XU308 |
USB Driver compatibility | ASIO |
Input supported sample rates | PCM 32bit / 192kHz (Dolby/DTS compatible) |
Output sample rates | PCM 24bit / 192kHz |
Compatibility | Windows XP 7/8/10 (32/64 bit) Mac OSX 10.6.4 and above Linux Android IOS 13.3.4 and above |
Output signal transmission distance | > 10 meters |
Dimensions | 91 x 20 x 50 mm |
Color | Silver |
Net weight | 120g |
Gross weight | 200g |
Package | 1x SilkLine SPDIFMAX |
Input | USB |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Max sampling rate | 192kHz |
Color | Silver |
Interface chip | XMOS XU208 |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Heinz-Juergen F.
Stephane N.
Stephane N.
Gregory G.
