With the E1x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This great interface offers a very high level of performance for perfectly transparent recording and playback.
All you need is a USB OTG cable to connect a smartphone directly for live streaming, with lossless sound transmission.
The interface requires an external power supply when used with an OTG smartphone.
You can connect the interface to a PC when you're using it for a live stream via your smartphone. By using a DAW to optimize the voice, you can enhance the sound quality of your live stream.
It's also possible to connect another smartphone to play an accompaniment or audio file while the first smartphone is live-streaming. What's more, you can even use this function to launch two live streams.
The E1x2 OTG features a microphone preamplifier module developed by Topping Professional with a noise figure of just -130.5dBu. Even at maximum volume, the E1x2 OTG can maintain a very low level of background noise, ensuring perfectly detailed recording. This architecture ensures that the audio signal is accurately transmitted for transparent sound.
Equipped with 48V phantom power, the E1x2 OTG is perfectly compatible with condenser and dynamic microphones.
Topping's unique LNRD module provides an extremely stable power supply for the AD/DA chip, enabling it to develop its full potential for pure audio transmission.
With a noise floor of just 1uVrms and an output impedance of 1 Ohm, the NFCA-LE headphone amplifier module lets you use sensitive headphones without suffering from distortion or noise.
The E1x2 OTG offers two levels of gain, high gain up to +17dBu and high output power with 2x580mW at 32 Ohm. The combination of this high gain and power allows the E1x2 OTG to easily accompany high-impedance headphones, up to 600 Ohm.
The zero-latency design lets you monitor your audio effects in real time, while recording or mixing.
The volume control knobs on the line output and headphone amplifier use an analog potentiometer, allowing more precise volume control.
Equipped with four 12-channel input mixers, the E1x2 OTG allows easy adjustment and control of audio effects. What's more, its 8 DAW channels and 46 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
The Topping Professional E1x2 OTG adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. It supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
The Topping Professional E1x2 OTG uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E1x2 OTG is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
1 | Activate / Deactivate direct monitoring |
2 | Input gain knob |
3 | Input level vumeter |
4 | Output levels vumeters |
5 | Line out level knob |
6 | Mix monitoring level adjustment |
7 | Headphone output volume control |
8 | instrument / micro / line level device input |
9 | Instrument / line in switch |
10 | 48V phantom power supply switch |
11 | Headphone amplifier gain switch |
12 | Headphone output |
13 | Power button |
14 | 5VDC power connector |
15 | USB-C connector (PC) |
16 | USB-C OTG connector (mobile) |
17 | Line out |
E1x2 OTG | E2x2 | E4x4 Pre | |
OTG interface | Yes | No | No |
Power supply | USB-C | USB-C | USB-C |
Interface type | USB 2.0 | USB 2.0 | USB 2.0 |
Monitoring | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) |
Input level indicator | 1 set of LED | 2 set of LED | 4 set of LED |
Output level indicator | 2 set of LED | 2 set of LED | 4 set of LED |
Mic preamp module | Ultra-linear | Ultra-linear | Ultra-linear |
Headphone amp | NFCA-LE | NFCA-LE | NFCA-LE |
Supported sampling rates | USB-C : PCM up to 24bit 192kHz OTG : PCM up to 24bit 48kHz | PCM up to 24bit 192kHz | PCM up to 24bit 192kHz |
Control software | Yes | Yes | Yes |
Supported OS | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android |
Power button | Yes | Yes | Yes |
Weight | 415g | 530g | 830g |
Mix channels | 4 | 3 | 4 |
DAW channels | 8 | 6 | 8 |
Loopback channels | 6 | 4 | 6 |
Product type | USB audio interface |
USB protocol | USB 2.0 (HS) OTG USB 2.0 (FS) |
Mic input | 1x XLR / Jack 6.35mm combo connector |
Instruments input | 1x XLR / Jack 6.35mm combo connector |
Line out | 2x Jack 6.35mm |
Headphone out | 1x Jack 6.35mm |
Direct zero-latency monitoring | Yes (with mix button) |
Input vumeter | Yes (1x8 LED indicator) |
Output vumeter | Yes (1x8 LED indicator) |
Headphone amp module | NFCA-LE |
Supported sampling rate | PCM up to 24bit 192kHz OTG : PCM up to 24bit 48kHz |
Control software | Yes (Topping Professional Control) |
DAW channels | 8x |
Mic input measurements (@ 24bit 96kHz) | |
Input noise | -130.5dBu @ A-wt, 150Ω |
THD+N | -110dB (0.0003%) @ A-wt |
Dynamic range | 118dB @ A-wt |
SNR | 118dB |
Crosstalk | / |
Frequency response | 20Hz - 40kHz (±0.2dB) |
Max input level | 8.6dBu |
Input impedance | 1.5kΩ |
Available gain | 58dB + 20dB (20db digital gain) |
Phantom power supply | 48V XLR connector |
Line input measurements (@ 24bit 96kHz) | |
THD+N | -107dB (0.00045%) @ A-wt |
SNR | 118dB |
Crosstalk | / |
Frequency response | 20Hz - 40kHz (±0.1dB) |
Max input level | 23.9dBu |
Input impedance | 9kΩ |
Connector | Jack 6.35mm TRS |
Mesures entrée instruments (@ 24bit 96kHz) | |
THD+N | -108dB (0.0004%) @ A-wt |
SNR | 118dB |
Crosstalk | / |
Frequency response | 20Hz - 40kHz (±0.3dB) |
Max input level | 14.8dBu |
Input impedance | 1MΩ |
Connector | Jack 6.35mm TS |
Line out measurements (@ 24bit 96kHz) | |
THD+N | -100dB (0.001%) @ A-wt |
Dynamic range | 115dB @ A-wt |
Dynamic range analogique | 127dB @ A-wt, -40dB atténuation |
SNR | 115dB @ A-wt |
Crosstalk | -128dB @ 1kHz |
Max input level | 14dBu |
Bruit | 1.8uVrms @ A-wt |
output impedance | 100Ω |
Connector | Jack 6.35mm TRS balanced |
Headphone output measurements (@ 24bit 96kHz) | |
Analog dynamic range | 132dB @ A-wt, -40dB atténuation |
Crosstalk | -120dB @ 1kHz |
Max output level | 0dBu @ Gain = L 17dBu @ Gain = H |
Noise | 1uVrms @ A-wt |
Output impedance | 1Ω |
Connector | Jack 6.35mm TRS stereo |
Headphone output power | 2x580W @ 32Ω, THD+N < 1% 2x380W @ 64Ω, THD+N < 1% 2x198W @ 150Ω, THD+N < 1% 2x105W @ 300Ω, THD+N < 1% 2x55W @ 600Ω, THD+N < 1% |
OTG Output measurements (@ OTG 24bit 48kH<-> Type-C 24bit 44.1-192kHz) | |
THD+N | -130dB @ A-wt |
Dynamic range | 138dB @ A-wt |
SNR | 138dB @ A-wt |
Crosstalk | -154dB @ 1kHz |
Frequency response | 20Hz - 20kHz (±0.1dB) |
Max output level | -0.5dBFS |
Power supply | 5VDC 0.8A via USB-C |
Dimensions | 14.5 x 12.9 x 5cm |
Weight | 415g |
Color | Black |
Input | Jack 6.35mm |
Input | USB |
Input | XLR |
Output | Jack 6.35mm |
Max sampling rate | 192kHz |
Color | Black |
Interface chip | XMOS XU308 |
