Very good sound card with professional sound. Works very well in Windows 11.
All the best!!!
Topping's E2x2 OTG is an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for perfectly transparent recording and playback.
The Topping E2x2 OTG is equipped with an ultra-linear microphone preamplifier module developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E2x2 OTG can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Equipped with 48V phantom power and a switch for activating or deactivating phantom power, the Topping E2x2 OTG is perfectly compatible with condenser and dynamic microphones.
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unlocking the chip's full potential for high-purity audio transmission.
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E2x2 OTG's NFCA-LE headphone amplifier module allows high-sensitivity headphones to be used without distortion and noise. The Topping E2x2 OTG offers two gain settings, a high gain of up to +17dBu and an output power of 2x580mW into 32Ω. The combination of this high gain and significant output power means that the Topping E2x2 OTG can easily accompany professional headphones with a high impedance, up to 600Ω.
The zero-latency design allows audio effects to be monitored in real time during recording or mixing, for improved productivity.
The volume knobs for the line output and headphone output use an analogue potentiometer, offering excellent precision for easy control of sound level.
Equipped with four 12-channel input mixers, the E2x2 OTG allows easy adjustment and control of audio effects. Furthermore, its 8 DAW channels and 6 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
The Topping E2x2 OTG adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. This supports high-resolution audio streams for recording and playback, up to PCM 24bit 192kHz.
The Topping E2x2 OTG uses two USB-C connectors for data transmission, including an OTG port, and one connector for power. All you need is a USB OTG cable to connect directly to your mobile phone for live streaming, providing lossless sound transmission quality. It is recommended that the auxiliary power connector is connected if the E2x2 OTG is used in conjunction with a desktop computer or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
1 | Mic/Instr/Line input |
2 | Mic/Instr/Line input |
3 | Headphone output 6.35mm Jack |
4 | Anti-theft lock |
5 | Power supply |
6 | USB-C input |
7 | USB-C OTG input |
8 | Optical Jack output |
9 | Auxiliary output 3.5 mm Jack |
10 | 6.35 mm Jack line outputs |
E1x2 OTG | E2x2 OTG | E2x2 | E4x4 Pre | |
OTG interface | Yes | Yes | No | No |
Power supply | USB-C | USB-C | USB-C | USB-C |
Interface type | USB 2.0 | USB 2.0 | USB 2.0 | USB 2.0 |
Monitoring | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) |
Input level indicator | 1 set of LED | 2 set of LED | 2 set of LED | 4 set of LED |
Output level indicator | 2 set of LED | 2 set of LED | 2 set of LED | 4 set of LED |
Module preamp micro | Ultra-linear | Ultra-linear | Ultra-linear | Ultra-linear |
Headphone amp | NFCA-LE | NFCA-LE | NFCA-LE | NFCA-LE |
Supported sampling rates | USB-C : PCM up to 24bit 192kHz OTG : PCM up to 24bit 48kHz | USB-C : PCM up to 24bit 192kHz OTG : PCM up to 24bit 48kHz SPDIF : PCM up to 24bit 192kHz | PCM up to 24bit 192kHz | PCM up to 24bit 192kHz |
Software control | Yes | Yes | Yes | Yes |
Supported OS | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android |
Power button | Yes | Yes | Yes | Yes |
Weight | 415g | 530g | 530g | 830g |
Mix channels | 4 | 4 | 3 | 4 |
DAW channels | 8 | 8 | 6 | 8 |
Loopback channels | 6 | 6 | 4 | 6 |
Product type | Audio interface |
USB protocol | USB 2.0 |
Microphone input | 2x XLR / 6.35mm jack combo connectors |
Entrées instruments | 2x XLR / 6.35mm jack combo connectors |
Line outputs | 2x Jack 6.35mm |
Headphone output | 1x Jack 6.35mm |
Auxiliary output | 1x Jack 3.5mm |
OTG output | 1x USB-C |
SPDIF output | 1x Optical Jack |
Direct zero-latency monitoring | Yes (with mix button) |
Input Vumeter | Yes (2x8 LED indicators) |
Output Vumeter | Yes (2x8 LED indicators) |
Microphone preamp modules | Ultra-linear |
Headphone amplifier modules | NFCA-LE |
Supported sampling rates | PCM up to 24bit 192kHz |
Software control | Yes (Topping Professional Control) |
DAW channels | 8x |
MICROPHONE INPUT MEASUREMENTS (@ 24BIT 96KHZ) | |
Equivalent input noise | -130.5dBu @ A-wt, 150Ω |
THD+N | -110dB (0.0003%) @ A-wt |
Dynamic range | 115dB @ A-wt |
SNR | 115dB |
Crosstalk | -140dB @ 1kHz |
Frequency response | 20Hz - 40kHz (±0.2dB) |
Max input level | 8.6dBu |
Input impedance | 1.5kΩ |
Available gain | 58dB + 20dB (20db digital gain) |
Phantom power | 48V XLR connector |
LINE INPUT MEASUREMENTS (@ 24bit 96kHz) | |
THD+N | -107dB (0.00045%) @ A-wt |
SNR | 115dB |
Frequency response | 20Hz - 40kHz (±0.1dB) |
Max input level | 23.9dBu |
Input impedance | 9kΩ |
Connectors | Jack 6.35mm TRS |
INSTRUMENT INPUTS MEASUREMENTS (@ 24bit 96kHz) | |
THD+N | -108dB (0.0004%) @ A-wt |
SNR | 115dB |
Frequency response | 20Hz - 40kHz (±0.3dB) |
Max input level | 14.8dBu |
Input impedance | 1MΩ |
Connectors | Connecteur Jack 6.35mm TS |
LINE OUTPUTS MEASUREMENTS (@ 24bit 96kHz) | |
THD+N | -100dB (0.001%) @ A-wt |
Analog dynamic range | 127dB @ A-wt, -40dB attenuation |
SNR | 115dB @ A-wt |
Crosstalk | -128dB @ 1kHz |
Max output level | 14dBu |
Noise | 1.8uVrms @ A-wt |
Output impedance | 100Ω |
Connectors | Balanced Jack 6.35mm TRS |
Auxiliary output measurements | |
Analog dynamic range | 122dB @ A-wt, -40dB atténuation |
Crosstalk | -108dB @ 1kHz |
Maximum output level | 8dBu |
Noise | 1.5uVrms @ A-wt |
Output impedance | 50Ω |
Connector | Balanced Jack 3.5mm TRS |
HEADPHONE OUTPUT MEASUREMENTS (@ 24bit 96kHz) | |
Analog dynamic range | 132dB @ A-wt, -40dB atténuation |
Crosstalk | -120dB @ 1kHz |
Max output level | 0dBu @ Gain = L 17dBu @ Gain = H |
Noise | 1uVrms @ A-wt |
Output impedance | 1Ω |
Connector | Jack 6.35mm TRS stereo |
Headphone output power | 2x580W @ 32Ω, THD+N < 1% 2x380W @ 64Ω, THD+N < 1% 2x198W @ 150Ω, THD+N < 1% 2x105W @ 300Ω, THD+N < 1% 2x55W @ 600Ω, THD+N < 1% |
OTG output measurements (@ 24bit 192kHz) | |
THD+N | -130dB (0.00003%) @ A-wt |
Dynamic range | 138dB @ A-wt |
SNR | 138dB @ A-wt |
Crosstalk | -154dB @ 1kHz |
Frequency response | 20Hz - 20kHz (±0.1dB) |
Max output level | -0.5dBFS |
Connector | USB-C OTG |
SPDIF output measurements (@ 24bit 192kHz) | |
THD+N | -144dB (0.000006%) @ A-wt |
Dynamic range | 144dB @ A-wt |
SNR | 144dB @ A-wt |
Crosstalk | -160dB @ 1kHz |
Max output level | 0dBFS |
Connector | Optical Jack |
Power supply | 5VDC 0.8A via USB-C |
Dimensions | 18.7 x 12.9 x 5cm |
Weight | 530g |
Color | Black |
Package | 1x E2X2 OTG Black 1x USB-A to USB-C Cable 1x USB-C to USB-C Cable 1x 6.35mm to 3.5mm Jack Adapter |
Input | Jack 6.35mm |
Input | USB |
Input | XLR |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
Max sampling rate | 192kHz |
Color | Black |
Interface chip | XMOS XU308 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Mika N.
