This low cost USB to SPDIF interface allows an efficient conversion of a signal from a micro USB input to SPDIF on a coaxial or optical Toslink output. It also provides a Jack 3.5mm headphone output and has its own volume control (3.5mm output only). The interface uses a PCM2704 conversion chip supporting PCM audio streams up to 16bit 48kHz.
| Specifications | |
| Product type | USB to SPDIF interface |
| Input | 1* Micro USB |
| Outputs | 1* Coaxial 1* Optical Toslink 1* Jack 3.5mm headphone output |
| Interface chip | PCM2704 |
| Supported sampling rates | PCM up to 16bit 48kHz |
| General | |
| Dimensions | 55*120*21mm |
| Color | Silver |
| Input | USB |
| Output | Jack 3.5mm |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Max sampling rate | 48kHz |
| Color | Silver |
