The Fosi Audio CA30 is a power amplifier for car audio systems. Designed around the Infineon IR4322 amplifier chip, it delivers 4×100W under 4Ω, or 2×320W under 4Ω in bridged mode, using a high-efficiency architecture that delivers stable current while limiting internal heat build-up. This design results in a SINAD ≥ 80dB and THD+N ≤ 0.008%, ensuring low distortion reproduction, while a signal-to-noise ratio ≥ 100dB and background noise limited to ≤ 200μV preserve the clarity of micro-information, regardless of the listening level.
Designed for car audio systems requiring both dynamic reserve and configuration flexibility, it can be used in four independent channels to power a front/rear set, or in two bridged channels to drive more demanding loads. Beyond pure performance, this approach is accompanied by a set of active protections to guard against overheating, short circuits, overvoltage, undervoltage and polarity reversal, continuously monitoring electrical parameters to secure the installation and speakers.
"I was surprised when Fosi told me they were aiming for car audio market. We are talking about a world where prices are less than what you buy a chunk of metal and massively exaggerated specs. Fosi improves on these with nice build quality, with competent performance and nearly achieving its specs, depending how much distortion you let in. Better use than 4 channel is bridged stereo where you get well over 250 watts (one channel driven).
I am going to recommend the Fosi CA30 car audio amplifier."
| Specifications | |
| Product type | Car amplifier |
| Inputs | 4x RCA 1x 8-pin Molex |
| Output | 4x Screw terminal block |
| Output power | 4x100W RMS @ 4Ω 4x160W RMS @ 2Ω 2x320W RMS @ 4Ω |
| SINAD | ≥ 80dB |
| Total harmonic distortion more noise (THD+N) | ≤ 0,008% |
| Signal-to-noise ratio (SNR) | ≥ 100dB |
| Background noise | ≤ 200μV |
| Protection | Overheating Short circuit Overvoltage Undervoltage Polarity reversal |
| Frequency response | 10Hz-40kHz |
| Low-pass filter | 50Hz-250Hz |
| High-pass filter | 50Hz-250Hz |
| Damping factor | ≥ 140 |
| General | |
| Power supply voltage | 12V DC |
| Dimensions | 186 x 101 x 44.2mm |
| Color | Black |
| Package | 1x Fosi Audio CA30 1x 8-pin ribbon speaker cable |
| Input | RCA |
| Input | Molex |
| Output | Screw terminals |
| Color | Black |
| Channel | 4 |
| Class | Class D / T |
| Amplifier chip | Infineon IR4322 |
| Power (W) | 100.0 |
| Power (W) | 320.0 |
| Remote Control | No |
