AUDIOPHONICS DAC1796 DAC PCM1796 24Bit / 192KHz DIY Kit
Audiophonics DAC1796 - DAC 24Bit 192KHz -PCM1796 DIY Kit
Reference : 6336
139,00 €tax incl.
115,83 € tax excl.
This product is no longer in stock
Here is the complete DAC Kit with all the elements necessary for its implementation based on the DAC 1796 V1.1 module.
ATTENTION: this is the Kit version, all the elements are to be assembled by your care (see photos).
We relied on a reliable value, a chip CS8416-CZ from Cirrus logicfor receiving SPDIF, coupled with a reference in the matter, the converter PCM1796 by Burr-Brown.
This DAC card converts a digital signal of a sampling frequency from 32 to 192KHz and this in 16 or 24 bit.
Version 1.1 of this card now includes 2 SPDIF inputs , a TOSLINK optics and a Coaxial.
The analog output is always present on the small white connector.
Great care has been taken to the analog output, it includes 3 high-end PDOs mounted on reference socket OP275.
The capacitors around the signal are all MKP and Vishay DALE resistor.
The power capacitors are of superior quality, 9x Panasonic FC 1500μF and Panasonic OSCON. In all 5 regulators is concerned to provide a stable and pure power supply, including 2 low noise closest to digital chips.
Ce DAC1796 also has a SCHAFFNER FN9222 filter, enabling you to filter EMI noise and obtain a clean current.
Features:/ Strong>
  • InOptical and Coaxial
  • SPDIF Reception by Cirrus Logic CS8416
  • Decoding up to 24Bit 192KHz by Burr-Brown PCM1796
  • AOP output Burr Brown OP275 mounted on stand
  • Analogue output via connector or directly on PCB
  • Power Capacitors Panasonic FC 1500μF and Panasonic OSCON
  • MKP Signal Capacitor and Vishay Resistors
  • Power supply via a single transformer 30VA 2x15V AC + 1x9V AC
  • Dimensions of the card: 160x70x29mm
  • Mounting hole distance: 145x55
     Forum Tutorial
This kit includes the following elements:
Colissimo - TNT - SoColissimo
4 reviews
Excellent Dac PCM1796
Ce Dac à base de PCM1796 et de CS8416 est excellent, surtout pour le prix. Je ne sais pas si l'on peut aller plus loin avec, mais la présence des fameux condos Sanyo oscon est un gage de qualité.
Comparé à mon Linn Akurate2, j'ai du mal à faire la différence....
This review has been posted for AUDIOPHONICS DAC1796 DAC PCM1796 24Bit / 192KHz DIY Kit
Prof-Shadocko
Excellent convertisseur ! Je connaissais déjà les produits Burr-Brown il y a 20 ans ! Genre PCM 63P qui était un 20 bits excellent et dont je me sers toujours... Ce PCM 1796 ne le surpasse pas et est bien dans le même esprit : douceur, précision, bon détachement des timbres, bonne dynamique... etc. A recommander sans modération ! A voir s'il est interessant de remplacer les AOP par des 2134 ou autre...
Exellent produit,quelques ajustements de coffret.
Résultat d écoute très bon d origine.Le changement AOP le rend bien meilleur.Le choix est vaste.
Pour ma part ,ceux que j ai monte mon transformé l écoute.
Je pense améliorer encore,alimentation,régulation et condensateurs
La base étant très bonne c est facile.
En suivant les explications, l'appareil peut être monté assez facilement. Le seul soucis a été que j'ai du légèrement agrandir les trous sur la plaque arrière pour faire passer les prises spdif, le percage initial étant un peu juste.
Le reste du montage s'est effectué sans soucis.
L'appareil a fonctionné correctement dès la première mise sous tension.
