Digital Interface CM-108 USB to SPDIF / I2S DTS
This module based on a CM-108 interface allows you to get a qualitative Toslink Coaxial and Optical SPDIF digital output from a 16bit 44.1/48kHz computer source.
Reference : 10753
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 06-10-2026.
Interface Digitale
Interface Digitale CM-108 USB vers SPDIF / I2S DTS
This module based on a CM-108 interface allows you to get a qualitative Toslink Coaxial and Optical SPDIF digital output from a 16bit 44.1/48kHz computer source. Natively supported by most operating systems on the market, its implementation is particularly simple. This interface is compatible with DTS streams under Windows 8 and 10 with the driver provided in the "Download" tab of this page.
Product typeDigital interface
Input1x USB-B
Outputs1x Coaxial
1x Optical Toslink
I2S output to solder
InterfaceCMedia CM-108
Supported sampling rate16bit 44.1/48kHz
Dimensions60 x 24 x 24mm
OutputCoaxial SPDIF
OutputOptical Toslink
OutputI2S
Max sampling rateDSD128
Interface chipCM-108
This module based on a CM-108 interface allows you to get a qualitative Toslink Coaxial and Optical SPDIF digital output from a 16bit 44.1/48kHz...
