AUDIOPHONICS PSU S3-LP Linear Power supply Module DC LT1083
4.3 / 5
Reference : 10285
39,90 €tax incl.
33,25 € tax excl.
The new model is available here: AUDIOPHONICS PSU S4-HP.
The Audiophonics PSU S3-LP power supply module has been designed to provide a clean power supply to an amplifier or other audio circuit.
It has a potentiometer and jumper to adjust the voltage from 5 to 24V from an AC voltage source of 5 to 22V AC respectively.
Its particularly rigorous design, and the quality of its components, make it an excellent choice for powering a digital amplifier or any other low voltage high-fidelity element such as certain DAC converters, headphone amplifiers, etc...
So many devices for which it contributes to improve the sound quality.
The Audiophonics PSU S3 makes use of 4 fast switching 2CZ2545 A9 diodes.
On the filtering side, 10 Rubycon capacitors of 2200uF/35V with an ESR of 0.0019 Ohm and a current capacity of 3.1A per capacitor.
Once the voltage is stabilised, it is then regulated by means of a LINEAR TECHNOLOGY LT1083, renowned for its low ripple (0.015%).
Features:
  • 4 diodes 2CZ2545 A9.
  • 2 diodes 1N5408.
  • 10 Rubycon capacitors 2200uF/35V.
  • Voltage regulator LINEAR TECHNOLOGY LT1083 5A.
  • 6 MKT capacitors
  • 2 Wima MKP capacitors for DC output smoothing.
  • Integrated discharge resistor
  • Output voltage adjustable by means of a blue potentiometer + jumper: (Transformer voltage must match)
    • Jumper On : Adjustable from 5 to 16V
    • Jumper Off : Adjustable from 12.5 to 24V
  • Optional DC input (next to GND): rectified and regulated voltage
Specifications :
  • Output voltage: Variable from 5 to 24V.
  • Maximum output current: Approximately 5A continuous.
  • Maximum connectable music power: Approximately 60W.
  • Dimensions: 130 x 60 (86 with heatsink) x 36mm.
  • Centre distances: 50mm, 120mm.
  • Weight: 204g.
  • Transformer voltage: 5 to 22V AC (12V AC for a 12V DC output, the transformer must deliver a rectified voltage of about 5V more than the desired voltage).
InputSolder pad
InputScrew terminals
OutputSolder pad
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)20.0
Output voltage (V)24.0
Output voltage (V)10.0
Output voltage (V)15.0
Output current (A)5.0
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
6 reviews
Rapport qualité prix remarquable
Très satisfait !
Utilisé ici pour alimenter un lecteur réseau livré d’origine avec une petite alimentation à découpage externe.
Progrès très net.
Penser à l'ajout d'un transfo alimentation.
This review has been posted for AUDIOPHONICS PSU S3-LP Linear Power supply Module DC LT1083
attention à la tension d'entrée cause échauffement
Dans un 1er temps j'ai mis 12v AC pour 5v DC utilisé mais 12v AC donne 16.8v DC donc un delta de 11.8 volt trop pour le LT 1083 qui fonctionne avec un delta de 5 à 8 volt maxi.
Donc 7 à 9 volt AC suffisent pour 5 volt DC et moins d'échauffement du régulateur.
William.B
bonne alim
Associée à un transfo torique 12V 50W pour une tension de 5v régulée.Cette alim devrait à terme remplacer l'alim IFI sur mon dac, elle alimente pour l'instant mon Raspberry auquel je vais associer un disque dur. Seule bémol le schéma électronique de la carte n'est pas fourni donc il faut suivre la piste ce qui n'est pas aisé. Personnellement j'aurais mis des condensateurs wima mkp à la place des mkt.
Danger
AC input voltage must not exceed 24,8V because input capacitor is only 35V DC.
Rectified AC 24.8V is 24.8*1.41=35V
Now I need new PSU.
SMSL M8
J'utilise cette alimentation avec le DAC SMSL M8, un pur bonheur en comparaison de l'alimentation à découpage livré d'origine.
Très facile à mettre en oeuvre avec un transformateur de chez AUDIOPHONICS, en 15 volts (15 ou 30VA).
Dans un premier temps j'ai alimenté le module en 30 volts, mais celui chauffe pas mal, le M8 ne nécessitant que 9 volts.
J'ai donc alimenté le module en 15 volts ce qui est largement suffisant pour obtenir les 9 volts requis en sortie pour le M8, ce qui a l'avantage de ne pas solliciter inutilement le module, car celui ci chauffe toujours mais juste ce qu'il faut. Le M8 est gourmand en courant.
Franchement a ce prix le gain en clarté et précision du M8 est "PHENOMENAL".
Source DSD et CDDA sur PC ASUS avec Foobar, Ampli casque DIY HA1-mk2 (classe A), casque AKG Q701 Quincy Jones.
Le réglage de la tension de sortie et enfantin et très stable réglé sur 9,5 volts.
Je redécouvre toute ma discothèque avec un plaisir immense.
Ce petit DAC est vraiment excellent, faut il lui donner ce qu'il faut pour l'alimenter.
