By buying this product you get 67 loyalty points
Audio Processor USB 28 / 56bit 8 to 12 channels
The MiniDSP C-DSP 8x12 is the next-generation processor for high-end Car Audio. The powerful 400MHz SHARC processor provides high-resolution audio at sampling frequencies up to 192kHz.
With a multitude of inputs and outputs in a sturdy compact 100% aluminum case, the C-DSP 8x12 is perfectly suited for simple stereo systems, surround sound systems with Subwoofer integration, but especially for advanced multichannel active systems.
The USB interface that does not require any driver is used to configure the audio processing power of the MiniDSP: EQ parameters on each input and output, adjustable compression and offset on all outputs, filters up to 48dB / octave, and advanced matrix mixer .
QFour full audio processing configurations are stored in flash memory, which are accessible to you instantaneouslyvia the supplied remote control, can be controlled by RJ45 cable or by infrared.
The car's dedicated hardware features include: an integrated power supply, an I / O for remote triggering, a wired remote control for the instrument panel or console mount, and a card slot micro SD for offline configuration and program updates.
Connections: Inputs | |
Analog | 3x RCA Stereo |
digital | 1x Coaxial SPDIF / 1x Optical Toslink |
Connectors: Outputs | |
Analog | 6x RCA Stereo |
DSP | ADSP21489 |
Sampling rate | 32bits 192kHz |
Configuration | 8 inputs, 12 outputs |
Input impedance | High level 68Ω / Low level 10kΩ |
Output impedance | 560Ω |
Calibration software | C-DSP 8x12 plug-in |
Filtering technology | IIR / FIR depending on the plug-in |
Miscellaneous | |
Dimensions | 205 x 122 x 41mm |
Weight | 820g |
Color | Black |
Housing material | 100% Aluminum |
Accessories | 1x RJ45 Ethernet cable 5m, 2x rack fastenersProfessional with Fasteners, Wired or Infrared Remote Control |
