DSP Stereo Numérique Dirac Live 24bit 96kHz
The DSP DDRC-22D fits between your digital source and your integrated preamplifier/amplifier, or even between two digital sources. It has been designed to radically transform your listening experience and allow you to rediscover your favorite audio installation and songs. MiniDSP and Dirac Live bring you here a solution for acoustic processing and digital correction with this unique combination of hardware and software.
The processor incorporates a sophisticated digital processing algorithm that intelligently corrects frequency and time errors caused not only by the listening room but also by the people in it. The result is an improved stereo image, greater clarity and realism, more accurate timbre and deeper bass. In short, the DDRC-22D is the product you need to correct the acoustics of your listening room, while enjoying an ergonomic and easy-to-use interface.
The case consists of a high-resolution 24bit 96kHz audio processor. It is accompanied by a UMIK-1 measuring microphone with its own calibration system, to obtain excellent results. The DDRC-22D can also be associated with this infrared remote control.
| Specifications | |
| Product type | DSP for measuring microphone |
| Input / Output resolution | 24bit |
| Internal sampling rate | 96kHz |
| Output sampling rate | 96kHz |
| Compatibility | Windows : Vista SP1, XP Pro SP2, Win7, Win8 MAC OS Minimum recommanded configuration : Intel Pentium III or AMD Athlon XP (SSE needed), 2Go RAM, 2 USB-A port |
| General | |
| Dimensions | 210 x 205 x 40mm |
| Weight | 3.2kg |
| Color | Black |
| Package | 1x MiniDSP DDRC-22D 1x USB-A to USB-B Cable 2x Optical cable 1x 5V 2A Power supply 2x Mounting brackets |
Connection diagram
SOFTWARE MODELING OF SOUND RECORDING FOR ACOUSTIC PROCESSING
BEFORE / AFTER Response curve
DIRAC LIVE SPECTRUM CORRECTION SOFTWARE INTERFACE
| Input | Optical |
| Input | SPDIF |
| Input | AES/EBU |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Output | AES/EBU |
| Max sampling rate | 96kHz |
| Color | Black |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
