MINIDSP FLEX DIGITAL Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth
The Flex Digital miniDSP is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor previously used with a redesigned input/output architecture to offer versatile connectivity. This version has an unbalanced RCA stereo input, as well as a complete digital input panel with Bluetooth, USB-B, coaxial and Toslink optical. The output is made in coaxial or optical.
4.5 / 5
By buying this product you get 64 loyalty points
Reference : 16467
649,00 €tax incl.
540,83 € tax excl.
Shipping date: 07-04-2026.
miniDSP Flex DIGITAL
miniDSP Flex Processeur Audio DSP Dirac Live SHARC ADSP21489 XMOS Bluetooth
An OLED display on the front panel and a volume controller make it easy to control the unit. Of course, the Flex series incorporates the powerful audio processing features developed by miniDSP: a flexible parametric equalizer, IIR and FIR filters, crossovers, the possibility to program the biquad filter and delay for each output... In addition, all systems can be software enhanced with the Dirac Live® correction solution for fine tuning over the entire frequency range.
The miniDSP Flex offers a wide range of uses and applications, whether in combination with a compact digital stereo preamplifier, for integration with a subwoofer or for active speaker optimization.
miniDSP Flex Digital Processeur Audio DSP Dirac Live SHARC ADSP21489 XMOS Bluetooth
The DIRAC license is not included, but available here.
MiniDSP Flex review by Audio Science Review (Amir)
What a nice combination of functionality, usability and performance! As with many DAC companies, it is clearly Minidsp has put strong focus on chasing away sources of noise and distortion. Yes, there is some work left to do with intermodulation distortion but other than that, measurement after measurement put a smile on my face. All AV processor and receiver companies lose any excuses they have for not providing this level of performance seeing how the Flex also implements various signal processing modules. "
Test du MiniDSP Flex par Audio Science Review (Amir)
Product typeDSP
ProcessorAnalog Devices DSP SHARC ADSP21489 400MHZ floating point
USB InterfaceXMOS
InputsBluetooth
1x USB-B
1x Coaxial
1x Optical Toslink
1x Stereo RCA
Outputs2x Coaxial
2x Optical Toslink
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Recording function via USB4 channel output processing
Processing sample rate32bit 96kHz
(32bit 48kHz with Dirac Live® license)
Analog input impedance100kΩ
Max input level2Vrms
Frequency response20Hz-20kHz ±0.1dB
SNR (digital to analog)137dB(A)
THD+N (digital to analog)-110dB (0.0003%) ±3dB
Crosstalk (digital to analog)-165dB
SNR (analog to analog)115dB(A)
THD+N (analog to analog)-108dB (0.0004%)
Crosstalk (analog to analog)-115dB
Filtering technologyFIR + IIR
Dirac Live® optional : 3x full range correction (20~20kHz)
DSP presetsUp to 4 presets
Power supply12VDC 1.6A (power supply included)
Consumpation7.5W
Standby consumption2.5W
Dimensions150 x 180 x 41mm
Package1x miniDSP Flex Digital
1x Remote control
1x Power supply
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate96kHz
2 reviews
Un très bon préampli/DSP numérique
Possédant le Flex TRS à sorties symétriques et des enceintes actives à DSP numérique, je souhaitais le remplacer par le Flex digital afin d'éviter les conversions AD/DA inutiles. Niveau son, rien à redire ni au niveau souplesse d'utilisation mais j'ai dû le renvoyer (merci Audiophonics !) car le signal d'horloge reste actif lorsque l'appareil est en Standby (MiniDSP me l'a confirmé). Or mes cela empêche mes enceintes de se mettre en veille. C'est bien dommage car c'est vraiment un bon appareil.
This review has been posted for MINIDSP FLEX DIGITAL Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth
Nettes améliorations
Ce minidsp Flex D vient en remplacement d'un Minidsp 4x10HD.
Avec l'aide de deux DAC1 Benchmark, l'idée était d'améliorer la qualité sonore du 4x10, chose réussie mais un peu normale eu égard aux moyens mis en oeuvre.
Parmi les améliorations :
- meilleure connexion logicielle
- télécommande moins capricieuse
- affichage sympa qui heureusement s'estompe automatiquement
- entrée analogique plus silencieuse
Les gros regrets sont :
- pourquoi un deux fois deux voies ? Il eut été beaucoup plus intéressant d'en faire 4 x 2 voies stéréo. C'est vraiment le gros regret, il suffit de voir comment les Nonodigi s'arrachent sur le marché de l'occasion. Du coup, la troisième voie a été filtrée en passif. Les sorties optiques ne sont qu'un dédoublement des sorties coaxiales.
- suppression de la possibilité de configurer une entrée avec le contrôle de volume désactivé, cette fonction était intéressante pour y brancher un ampli
C'est vraiment dommage pour ces deux points car ce sont des fonctions qui ne coutent rien d'autre qu'une programmation logicielle, mais il n'y a pas d'autre alternative à un tel produit sur le marché, ce minidsp reste donc la seule possibilité confortable et abordable pour faire de la filtration active, mais en deux voies uniquement à la base.
The Flex Digital miniDSP is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor previously...
