MINIDSP FLEX EIGHT Digital Audio Processor DSP 2x8 Channels SHARC ADSP21489 XMOS Bluetooth 5.0 aptX HD LDAC
The miniDSP Flex Eight is the latest member of the miniDSP Flex line of advanced audio processors. Here the brand takes advantage of its flexible hardware architecture to fit eight channels of digital signal processing and a high-quality analog output stage into a compact package.
By buying this product you get 79 loyalty points
Reference : 16775
799,00 €tax incl.
665,83 € tax excl.
miniDSP Flex Eight
miniDSP Flex Eight Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS Bluetooth 5.0 aptX HD LDAC
With multiple digital inputs and eight single-ended analog output channels, the Flex Eight miniDSP can support up to four stereo channels of active speakers. Flexible 2x8 signal routing allows for many other configurations, such as two channels, three channels, and multiple subwoofers. As always, a full suite of proven audio processing features is included: parametric EQ, IIR and FIR filters, crossovers, advanced biquad programming and delay, on each output channel.
The Flex Eight has stereo digital inputs in USB-B, coaxial, Toslink optical and Bluetooth (aptX, LDAC) formats. An OLED display on the front panel and a volume control knob allow for easy control of the device. In addition, settings can be easily changed using the Stereo Dirac Live® acoustic correction software.
The miniDSP Flex Eight is the perfect solution for a compact and modern integrated active speaker and subwoofer system, offering many possibilities and adapting to various scenarios.
DIRAC licence not included, but available here.
Product type2x8 Channels DSP
InputsBluetooth 5.0
1x USB-B
Coaxial
Optical Toslink
Outputs8x Single-ended RCA
CPUAnalog Devices SHARC ADSP21489 400MHz 32bit floating point
USB InterfaceXMOS
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
SNR128dB(A)
THD+N0.0003% @ -111dB
Supported sampling ratesPCM up to 32bit 96kHz
Analog output impedance200Ω
Max analog output level2Vrms
Frequency response20Hz - 20kHz ±0.05dB
SNR128dB(A) avec DRE (Digital Range Enhancer)
THD+N0.0003% (-111dB) @ 1kHz
Crosstalk-120dB
Filtering technologyIIR (10 bands/outputs) + FIR
Supply voltage12VDC 1.6A (power adapter included)
Consumption4W
Dimensions150 x 180 x 41mm
Package1x miniDSP Flex Eight
1x Power adapter
1x Remote control
Max sampling rate96kHz
The miniDSP Flex Eight is the latest member of the miniDSP Flex line of advanced audio processors. Here the brand takes advantage of its flexible...
