By buying this product you get 149 loyalty points
With the Harmony DSP 8x12, MiniDSP is offering a 12- channel amplifier with Dirac Live-compatible DSP specially developed for use in a car. It incorporates a number of hardware features designed directly for the vehicle environment, such as an isolated on-board power supply, remote trigger input/output and a wired remote control with OLED display for the dashboard.
Flexible output configurations cater for a wide variety of system set-ups: each output can offer 40 Wrms of output power or be used as a line out output to provide a signal to an external amplifier. Furthermore, each pair of outputs can be configured in parallel BTL mode for 6x80W output into 2 Ω. Its USB input supports up to a total of 6 channels, so you can, for example, subdivide your signal for digital filtering using the Dirac Live licence supplied with the product, and thus have a stereo signal for tweeters, subwoofers and midrange drivers.
Furthermore, the Harmony DSP 8x12 comes with a Dirac Live license and also includes MiniDSP's audio processing solutions, such as a parametric equalizer, compressor, adjustable delay, filters up to 48 dB/octave and an advanced matrix mixer, allowing you to easily customize the sound to suit your listening environment.
Product type | Audio Processor DSP Power amplifier |
Processor | SHARC Digital Signal Processor ADSP21489 |
Internal sampling rate | 48kHz |
Control | Driverless USB 2.0 control interface from Windows or Mac |
Inputs | USB-B up to 6 channels at 44.1kHz or 48kHz Toslink optical up to 2 channels, from 44.1kHz to 192kHz |
Outputs | 12x Molex, A2B multichannel |
Output power | 12x 40W RMS @ 4Ω, BTL mode 6x 80W RMS @ 2Ω, PBTL mode |
Total harmonic distortion more noise (THD+N) | < 0.03 % @ 1kHz 40W, BTL mode < 0.03 % @ 1kHz, line out |
Signal-to-noise ratio (SNR) | > 107 dB @ 1kHz 40W, A-weighted > 102 dB @ 1kHz, A-weighted, line out |
Frequency response | 20Hz – 20kHz (±0.5dB) 20Hz – 20kHz (±0.2dB), line out |
Crosstalk | < –80dB @1kHz |
Output mode | BTL mode for impedance above 2Ω PBTL mode for impedance between 1Ω and 2Ω Line out mode to drive an external amplifier |
Line out level | 5Vrms |
DSP processing | Dirac Live correction (8 ch), matrix mixer, miniDSP processing on all 12 outputs |
Configuration presets | Four presets for Dirac Live and miniDSP processing |
Body materials | Powder-coated steel with aluminium heatsink |
Power supply voltage | 10-16V DC |
Dimensions | 321 x 150 x 45 mm |
Remote control dimensions | 102 x 23 x 41 mm |
Color | Silver |
Package | 1x MiniDSP Harmony DSP 8x12 1x Dirac Live license 2x Speaker wiring harness 1x 1m USB cable 1x OLED remote control module 1x 5 m remote control cable |
Input | Optical |
Input | USB |
Output | Molex |
Max sampling rate | 192kHz |
Color | Silver |
Channel | 12 |
Class | N/A |
Amplifier chip | N/A |
Power (W) | 40.0 |
Remote Control | Yes |
