MINIDSP HARMONY DSP 8x12 Audio Processor DSP 12 Channel Amplifier
New
With the Harmony DSP 8x12, MiniDSP is offering a 12- channel amplifier with Dirac Live-compatible DSP specially developed for use in a car. It incorporates a number of hardware features designed directly for the vehicle environment, such as an isolated on-board power supply, remote trigger input/output and a wired remote control with OLED display for the dashboard.
By buying this product you get 149 loyalty points
Reference : 20760
1 499,00 €tax incl.
1 249,17 € tax excl.
MiniDSP Harmony DSP 8x12 Audio Processor DSP SHARC ADSP21489 12 Channel Amplifier 40W 4 Ohm Dirac Live
MiniDSP Harmony DSP 8x12 : Front view
Flexible output configurations cater for a wide variety of system set-ups: each output can offer 40 Wrms of output power or be used as a line out output to provide a signal to an external amplifier. Furthermore, each pair of outputs can be configured in parallel BTL mode for 6x80W output into 2 Ω. Its USB input supports up to a total of 6 channels, so you can, for example, subdivide your signal for digital filtering using the Dirac Live licence supplied with the product, and thus have a stereo signal for tweeters, subwoofers and midrange drivers.
Furthermore, the Harmony DSP 8x12 comes with a Dirac Live license and also includes MiniDSP's audio processing solutions, such as a parametric equalizer, compressor, adjustable delay, filters up to 48 dB/octave and an advanced matrix mixer, allowing you to easily customize the sound to suit your listening environment.
Product typeAudio Processor DSP
Power amplifier
ProcessorSHARC Digital Signal Processor ADSP21489
Internal sampling rate48kHz
ControlDriverless USB 2.0 control interface from Windows or Mac
InputsUSB-B up to 6 channels at 44.1kHz or 48kHz
Toslink optical up to 2 channels, from 44.1kHz to 192kHz
Outputs12x Molex, A2B multichannel
Output power12x 40W RMS @ 4Ω, BTL mode
6x 80W RMS @ 2Ω, PBTL mode
Total harmonic distortion more noise (THD+N)< 0.03 % @ 1kHz 40W, BTL mode
< 0.03 % @ 1kHz, line out
Signal-to-noise ratio (SNR)> 107 dB @ 1kHz 40W, A-weighted
> 102 dB @ 1kHz, A-weighted, line out
Frequency response20Hz – 20kHz (±0.5dB)
20Hz – 20kHz (±0.2dB), line out
Crosstalk< –80dB @1kHz
Output modeBTL mode for impedance above 2Ω
PBTL mode for impedance between 1Ω and 2Ω
Line out mode to drive an external amplifier
Line out level5Vrms
DSP processingDirac Live correction (8 ch), matrix mixer, miniDSP processing on all 12 outputs
Configuration presetsFour presets for Dirac Live and miniDSP processing
Body materialsPowder-coated steel with aluminium heatsink
Power supply voltage10-16V DC
Dimensions321 x 150 x 45 mm
Remote control dimensions102 x 23 x 41 mm
ColorSilver
Package1x MiniDSP Harmony DSP 8x12
1x Dirac Live license
2x Speaker wiring harness
1x 1m USB cable
1x OLED remote control module
1x 5 m remote control cable
OutputMolex
Max sampling rate192kHz
ColorSilver
Channel12
ClassN/A
Amplifier chipN/A
Power (W)40.0
Remote ControlYes
MINIDSP HARMONY DSP 8x12 Audio Processor DSP SHARC ADSP21489 12 Channel Amplifier 40W 4 Ohm Dirac Live
With the Harmony DSP 8x12, MiniDSP is offering a 12- channel amplifier with Dirac Live-compatible DSP specially developed for use in a car. It...
