MINIDSP MCHSTREAMER Interface USB XMOS to I2S / SPDIF / ADAT / TDM/ DSD / PDM 32bit 384kHz DSD256
The MiniDSP MHC Streamer is an asynchronous multi-channel USB interface that supports many input and output formats, leveraging XMOS and MiniDSP expertise. The module includes a high-quality XMOS Xcore 200 USB interface chip to ensure excellent sound reproduction
Reference : 13870
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 07-04-2026.
MiniDSP MHCStreamer
Interface USB XMOS to I2S / SPDIF / ADAT / TDM / DSD / PDM 32bit 384kHz DSD256
MiniDSP MHCStreamer kit Interface USB XMOSvers I2S / SPDIF / ADAT / TDM / DSD / PDM 32bit 384kHz DSD256
The MiniDSP MHC Streamer is an asynchronous multi-channel USB interface that supports many input and output formats, leveraging XMOS and MiniDSP expertise. The module includes a high-quality XMOS Xcore 200 USB interface chip to ensure excellent sound reproduction. Using one of the MiniDSP firmware provided, the MHC Streamer is able to support data transmission in Toslink Optics, ADAT, Coaxial SPDIF, I2S, TDM, DSD and PDM. This USB Audio Class 2 (UAC2) interface is a true Swiss army knife, ideal for product and audio program developers who need an interface for PC / Max, Linux, iOS or Android. This interface even supports format conversion from 16x PDM MEMS microphone to I2S, making this module an incredible tool for developing spatial filtering (beamforming) or speech recognition algorithms.
Product typeUSB to Optical / I2S / SPDIF / ADAT / TDM / DSD / PDM Interface
USB interface chipXMOS Xcore 200
CompatibilityWindows
Mac
Linux 2.0
Android
iOS (with camera kit)
Logic level formatsSPDIF : Stereo in/out - up to 24bit 192khZ
I2S : Up to 8 bidirectionnal channels - up to 32bit 384kHz
TDM8 : Up to 24 bidirectionnals channels - up to 96kHz
PDM : Recording up to 16 channels - up to 24bit 48kHz
DSD : Up to 8 channels - up to DSD256
Optical input & outputToslink : 44.1/48/88.2/96/176.4kHz
ADAT : 8 channels ADAT mode @ 48/44.1kHz and 4 channels ADAT mode @ 96kHz
Expansion connector2x12 pins, 2mm pitch
PDM to I2S conversionUp to 16 MEMS microphones
Mounting2 Brackets allow easy chassis mounting with M3 threaded hole
Power supply5V 300mA DC via USB or external power supply
Dimensions13 x 40 x 62mm
Package1x MHC Streamer module
1x USB cable 1m
2x Optical Toslink cable
2x 2x6 Pins cables with 2mm pitch
OutputOptical Toslink
OutputI2S
OutputCoaxial SPDIF
Max sampling rateDSD256
Max sampling rate384kHz
ColorBlue
2 reviews
MiniDSP MCHStreamer
Have been working with its previous version since 2013 without a single hitch. I integrated the new one in a multitrack interface setup (24ch) and is working flawlessly from day one. Albeit not really cheap, it' s worth its price..Audiophonics service prompt as always.
This review has been posted for MINIDSP MCHSTREAMER Interface USB XMOS to I2S / SPDIF / ADAT / TDM/ DSD / PDM 32bit 384kHz DSD256
Very versatile, although not cheap
Veritable Swiss Army Knife for USB connectivity. Although this is not a cheap item, it is very useful. I use it for Toslink SPDIF to USB for my MacBook Pro which it does perfectly, but it can be configured for I2S in/out, Coax in/out, ADAT depending on the loaded firmware. Installing the firmware is easy enough.
Finding a decent Toslink to USB receiver that is better than 16 bit/44.1Khz is quite tricky. There is the Soundblaster X-Fi that can do this, but I was worried about Mac compatibility.
This works perfectly and can be powered by USB or with a 5V header on the board.
The USBStreamer would have sufficed for the rates that I record my vinyl at, but this was only marginally more expensive, and handles higher rates and DSD if I ever want to go that direction in future.
The MiniDSP MHC Streamer is an asynchronous multi-channel USB interface that supports many input and output formats, leveraging XMOS and MiniDSP...
