By buying this product you get 229 loyalty points
Tonewinner's AT-3000 is a 14-channel audio/video processor and integrated amplifier, ideal for home cinema integration in 7.1.6 or 9.1.4 configurations. It supports all the current audio formats such as Dolby Atmos, Dolby True HD and DTS:X, as well as all their previous iterations. Furthermore, the AT-3000 supports video streams up to 4K and is compatible with HDR technology. Finally, 16 line outputs are available if you only want to use the A/V processor to support 9.3.4 or 7.3.6 formats.
Tonewinner's AT-3000 offers a total amplification power of 1680W at 8Ω. This power is distributed so that the right, left and centre channels each receive 240W and the other 8 surround channels each receive 120W.
The AT-3000's audio signal processing is largely based on two Cirrus Logic CS42528 chips, acting as DAC, ADC and SPDIF receiver. These ensure high-quality sound reproduction, thanks in particular to a wide dynamic range and very low levels of distortion and noise.
The video processing section for the AT-3000's 6 HDMI inputs and 2 outputs uses a Panasonic MN864788 controller. This supports 32bit streams, resolutions up to 4K (3840 x 2460px) 60Hz and is compatible with RGB/YUV 4:4:4 colour spaces.
Combined with these chips, an Analog Devices ADSP-21573 SHARC floating-point DSP decodes Dolby Atmos and DTS:X audio formats to create a truly immersive and coherent sound experience, with excellent channel separation.
Thanks to the ETM-2 measurement microphone (sold separately), the AT-3000 is capable of automatically calibrating and correcting the acoustics of your audio system. The microphone captures the sound information emitted by your speakers and applies automatic equalisation to each channel, depending on your listening position.
Furthermore, in addition to automatic calibration, you can adjust the equalisation manually to create your ideal sound space. You can also save your various settings and load them at will, so that they always perfectly match the way you use the AT-3000. Note that restoring factory settings does not erase previously saved configurations.
For each channel, the AT-3000 lets you set volume levels and limits that can be saved and applied as soon as the unit is switched on. This gives you total control to shape your sound space as you see fit.
Furthermore, the AT-3000 includes a Bluetooth receiver. This enables wireless audio streaming from a smartphone or tablet, for example. Playback can then be controlled directly from your portable device, making it quick, easy and convenient to use.
1 | RCA line out |
2 | RCA inputs |
3 | Coaxial inputs |
4 | Toslink optical inputs |
5 | HDMI SUB output |
6 | Bluetooth antenna |
7 | HDMI eARC output |
8 | Micro calibration connector |
9 | TF card slot |
10 | IR input |
11 | Trigger output |
12 | Micro-USB input |
13 | RS232 port |
14 | HDMI inputs |
15 | XLR SUB outputs |
16 | Speaker terminals |
17 | Power supply connector |
Product type | Audio / Video processor Integrated Amplifier |
Channels | 14 channel |
Inputs | Bluetooth 6x HDMI 2.1 4x Stereo RCA 2x Coaxial 2x Optical Toslink 1x TF card slot 1x Micro-USB |
Outputs | 2x HDMI 2.1 3x XLR SUB 11x Speaker terminals 16x RCA line out |
Other connectors | 1x RS232 1x Microphone calibration connector 1x IR Input 1x Trigger output |
Supported audio formats | Dolby Atmos Dolby True HD DTS/X DTS Virtual:X |
Supported video formats / resolutions | 4K 3D eARC CEC Standby pass-through Dolby Vision HDR10 |
HDCP version | 2.2 |
eARC support | On an output |
CEC support | On 5 inputs |
Automatic EQ calibration | Yes |
Lip Synchronization | Up to 1000ms |
RS232 support | Valeur |
Output impedance | 8Ω |
Output power | Left, right and centre channels : 240W @8Ω Surround channels : 120W @8Ω |
Gain | ≥38dB |
Total harmonic distortion (THD) | ≤0.03% |
Signal-to-noise ratio (SNR) | ≥95dB |
Frequency response | 10Hz - 50kHz (+1/-3dB) |
Supply voltage | 110-115V AC 60Hz 220-230V AC 50Hz |
Dimensions | 431 x 439 x 218mm |
Weight | 22.1kg |
Color | Black |
Package | 1x Tonewinner AT-3000 1x Remote control 1x Power cable 1x HDMI 4K cable |
Input | HDMI ARC |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | SD Card |
Input | RCA |
Input | Optical |
Input | HDMI |
Output | Speaker terminal |
Output | HDMI |
Output | RCA |
Output | XLR |
Max sampling rate | NC |
Color | Black |
