TONEWINNER AT-500 AV Processor / Home-Theater Preamplifier
The Tonewinner AT-500 is an 8K home cinema processor designed for immersive configurations up to 9.3.4 or 7.3.6. It provides full decoding of Dolby Atmos and DTS:X formats, compatibility with HDR video signals (HDR10+, Dolby Vision, HLG, Dynamic HDR) and features an HDMI eARC output. Its automatic calibration and manual equaliser allow for precise acoustic adjustment, while the mobile app provides intuitive control of its main functions.
By buying this product you get 139 loyalty points
Reference : 21292
1 390,00 €tax incl.
1 158,33 € tax excl.
Shipping date: 07-04-2026.
Tonewinner AT-500 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6
Tonewinner AT-500 : Front view
Tonewinner AT-500: 8K home cinema processor
The AT-500 complies with the 8K standard: it has 6 HDMI inputs and 2 HDMI outputs, with HDMI inputs 1 to 3 accepting native 8K signal pass-through and upscaling. This compatibility allows 8K sources to be integrated and ensures ultra-high definition image transmission without prior quality conversion.
Tonewinner AT-500 with television
Tonewinner AT-500 : example of Dolby Atmos installation
Tonewinner AT-500: 9.3.4 and 7.3.6 configurations
The AT-500 can support immersive audio configurations with up to 9 front channels, 3 or 7 side or rear channels, and 4 height channels, i.e. 9.3.4 or 7.3.6 depending on the coverage areas. This means that, regardless of the room in which it is used, the AT-500 will integrate seamlessly, allowing you to get the most out of your audio and video content.
Tonewinner AT-500: Dolby Atmos and DTS:X decoding
The AT-500 is compatible with Dolby Atmos and DTS:X audio format decoding, including Dolby Atmos upmixing to create a truly immersive and consistent sound experience with excellent channel separation.
On the video side, it supports HLG, HDR, Dolby Vision, HDR10+ and Dynamic HDR formats in pass-through mode without conversion, in order to preserve the original image.
Tonewinner AT-500 : Family in front of a television set
Tonewinner AT-500 : Automatic calibration
Tonewinner AT-500: Automatic calibration
With the ETM-2 measurement microphone (sold separately), the AT-500 can automatically calibrate and acoustically correct your audio system. The microphone captures sound information from your speakers and applies optimal automatic equalisation to each channel, based on your listening position.
Tonewinner AT-500: To go further in equalisation...
In addition to automatic calibration, it is possible to adjust the equalisation manually. The Tonewinner AT-500 provides an 11-band parametric equaliser for the left, right and centre channels and a 5-band equaliser for the surround, top and bass channels. This equalisation can be done directly from the device's graphical interface.
Tonewinner AT-500 : equalisation
Tonewinner AT-500 accompanied by a tablet, a television and a smartphone
Tonewinner AT-500: Bluetooth
In addition to a wide range of connectivity options, the AT-500 features a built-in Bluetooth receiver. This allows wireless audio streaming from a smartphone or tablet, for example. Playback is controlled directly from your mobile device for simple, fast and convenient use.
Tonewinner AT-500: Mobile application
The Tonewinner AT-500 can also be fully controlled from a dedicated mobile app, available for Android and iOS. This app allows complete control of the processor without having to access the television interface or physical remote control, enabling you to manage sources, volume, audio modes and equalisation, as well as playback from a USB stick or SD card.
Product typeAudio / Video processor
Home Cinema preamplifier
ChannelsTotal : 16 channels
InputsBluetooth
6x HDMI
3x Stereo RCA
2x Coaxial
2x Optical Toslink
1x Micro SD slot
1x USB-A (USB Host)
OutputHDMI 2.1 (including 1 eARC)
RCA 9.3.4 channels
XLR 9.1.4 channels
Other connectors1x RS232
1x trigger output 5V
Supported audio formatsDolby Atmos
DTS/X
Dolby True HD
Dolby Digital Plus
DTS Master
DTS Hi-Res
DTS Upmix
DTS Neural X
Supported video formats / resolutions8K, YUV 4:4:4
Dolby Vision
HDR10 / HDR10+
HLG
HDCP version2.3
eARC support
Automatic EQ calibration
Lips SynchronizationUp to 1000ms
Output level4Vrms ±1dB
Total harmonic distortion (THD)≤0.004%
Signal-to-noise ratio (SNR)≥110dB
Frequency response10Hz-65kHz
Channel separation≥90dB
Supply voltage100-240VAC 50/60Hz
Maximum consumption30W
Weight4.3kg
Package1x Tonewinner AT-500
1x ETM-3 measurement microphone
1x Remote control
1x Power cable
InputSD Card
InputHDMI
OutputHDMI eARC
OutputHDMI
Max sampling rateNC
2 reviews
Tonewinner AT-500
Correspond bien à mes attentes. Quelles sont les différences entre les modes "Pure" et "Direct"? Mais j'ai constaté un bug: sur certaines entrées, je n'ai pas le son. Je suis obligé de changer le mode (audio) de Direct jusqu'à "Dolby Upload" pour obtenir du son, puis je reviens au mode "Direct" que j'ai choisi. J'ai tenté de me connecter en WiFi pour réaliser une mise à jour (si elle existe), mais je n'ai pas pu rentrer ma clé WEP, le password WiFi ne permet pas de rentrer tous les caractères (et je ne sais pas si les majuscules sont prises en compte.....
This review has been posted for TONEWINNER AT-500 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6
Très bien !
Le préampli tant attendu est arrivé et c'est un succès.
Sur mon ancien ampli AVR4700 j'utilisais un SMSL SU-9 pour écouter mes disques en stéréo et le rendu était très bon, ben je dois dire que sur ce préampli la différence avec le SU-9 devient très très subtile.
Sans corrections, j'ai beaucoup de basses, les infra-basses de "Welcome to the World of Plastic Beach" de Gorillaz sortent quasi aussi fortes que les basses "standard", il y'en a presque trop :-)
Je ne suis pas fan des logiciels de corrections de l'accoustique mais je vais tester le soft mis à dispo par Tonewinner pour voir si ça me parle.
J'ai eu un petit "bug" en changeant à la volée les entrées HDMI, mais rien de catastrophique (freeze). Reboot et hop c'est reparti.
A ce prix là, très content de mon achat.
NB: je drive des KEF R-900 (LR) et KEF série Q (SR), Topping B-200 (L/R) et Audiophonics HPA-HDN250N (6x pour le SR), pas de Sub. Câbles Pangea, Cardas et Audiophonics.
The Tonewinner AT-500 is an 8K home cinema processor designed for immersive configurations up to 9.3.4 or 7.3.6. It provides full decoding of Dolby...
