The DDRC-88D fits between your digital source and your DAC.
By buying this product you get 119 loyalty points
A fully digital DSP used with the DAC of your choice
Like all DSP Dirac Live, DDRC88-8 offers to measure your listening space in all its complexity to automatically apply it several levels of acoustic compensation. In other words, this device is able to hear the specific sound to your installation in a given part to compensate for imperfections (as the resonance frequency of the room, for example, or latency caused by speaker speaker off-axis in a chamber). The processing algorithm is even able to correct variations of freqency and time caused by the physical presence of people listening in the room.
The DDRC-88D and provides a sound surprising clarity that highlights the qualities of a facility rather than its shortcomings. This results in an improved stereo image that unfolds with great sharpness, increased realism, more precise tone and deeper bass.
The special live Dirac DSP is to offer an extremely simple configuration method based on the successive positioning of a specific micro following a methodology step by step. In other words, simply tell the software your sound ambitions (life-size movie theater, home theater or listening room) and it will tell you where to position the microphone. Dirac will then automatically take action to "diagnose" the room and installation in comparison with an ideal model. This method of DSP configuration allows a result approaching the acoustic treatment without requiring any work or special knowledge in acoustics.
This stepwise adjustment allows you to enjoy a specifically configured DSP to meet your expectations in terms of problems inherent in your listening / listening room.
Naturally, the DDRC-88D algorithm is capable of handling multiple channels simultaneously. This will be used to configure a DSP sound systems on up to 8 channels (7.1). Automatic configuration of such a facility does not impose additional complexity.
Beyond the automatic configuration (which compares the extent to render ideal reference sound) it is possible to visualize the frequency response measured as well as the proposed correction for each channel. According to their preferences, the user can change the rendering of reference and / or the proposed correction.
The DRRC-88D DSP can also perform corrections from an analysis of sound pulses. This achieves a high level of accuracy in severe, particularly when it comes to percusifs elements. They will be able to evolve in the musical sound stage rather than in the sound stage of the listening room, which is a marked improvement.
For easy integration into complex systems, DSP DDRC-88D has a very intuitive connection system. DB25 a single cord is connected to the camera body. The latter is divided into 8 to give 4 AES-EBU stereo inputs and four AES-EBU stereo outputs.
In order not to tangling brushes, each of these inputs and outputs is identified by a simple color code.
| Canal | Color |
| In 1&2 | Purple |
| In 3&4 | Blue |
| In 5&6 | Vert |
| In 7&8 | Orange |
| Out 1&2 | Yellow |
| Out 3&4 | Red |
| Out 5&6 | Gris |
| Out 7&8 | Brown |
The façade interface is very simple.
A volume knob also serves to select one of the four DSP recorded profiles. 4 LED identify the profile in use.
| Specifications | |
| Processor | 32bit floating point |
| Resolution input / output | 24-bit |
| Sampling frequency | Indexed on the frequency detected at the first input.If the first input has no signal, 48kHz |
| Entrance | 4x stereo AES-EBU (8 channels) |
| Exits | 4x stereo AES-EBU (8 channels) |
| Save settings | Yes (4 preset storage locations) |
| Volume Knob | Yes |
| infrared remote control | Not included |
| remote control functions | Volume + / Volume - / Next Preset / Previous Preset / Mute / Dirac Live on & off |
| Universal 5V adapter | Included |
